Thread: DE Question
    DE Question
    I have always been unsure of how much DE I should be putting in my filter. I have a Hayward Pro Grid and my pool is 36,000 gallons. I have been putting 5lbs in for initial charge and then 3-4 after a backwash. I have no idea if any of that is correct! Does anybody know?
    Cleveland, Ohio
    IG 36,000 gallons. Vinyl Liner, Hayward ProGrid 3620 DE Filter, Hayward Super Pump, Hayward Gas Heater
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Re: DE Question
    It depends on the size of the filter. Hayward Pro Grid comes in 4 sizes, as far as I can tell. Somewhere there should be a label that tells you the model number. If we have that, it should be easy to find out how much DE you need.
    Re: DE Question
    It is the 3620.
    Cleveland, Ohio
    Richard320's Avatar
    Jan 2010
    19,031
    Re: DE Question
    The manual says 4.5 lbs for initial coating. 80% of that would be 3.6 lbs after backwashing.
    Re: DE Question
    thanks!
    Cleveland, Ohio
