Thread: FC won't go up
    May 2011
    whitehall, pennsylvania
    5
    FC won't go up
    Added 8 1.5 gallon jugs of bleach @6% over the past 48 hours added 4 lbs of shock and have 4 3inch tabs my chlorinator and still won't rise to appropriate levels **smh**
    approximately 25,000 gallons
    Pentair FNS D.E. 60 filter
    Inground Pool (concrete)
    Hayward Super Pump2 1.5 horse
    Re: FC won't go up
    Could you post a full set of water test results and describe how your water looks?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: FC won't go up
    Are you using test strips? If so, you may have so much FC that it's bleaching out the colors! On the other hand, if the pool is green and thick enough to walk upon the surface, what you describe would not be surprising.
    We really need more information.
