Thread: How close can you put a french drain to an AGP?
    Apr 2011
    Ohio
    97
    If I install some kind of drainage around the pool, how close is safe? Would I dig a small trench around the pool, or just lay some piping around the pool, before I even backfill, after the installation?
    14.6K gal., 24ft, 54" above ground. 2HP, 2speed Hayward pump (4psi low, 18psi hi), 150sqft cartridge filter. 4x20 solar panel (6 psi).
    30,419
    Re: How close can you put a french drain to an AGP?
    My thinking of a true French drain is to lay slotted 4" pipe in the bottom of a trench, usually 12-18" deep and fill it with clean rock. Since the rock won't compact, you can put it as close to the pool as you like.
