Thread: Still have leak and can NOT find it
    Jul 2008
    Bucyrus, Ohio
    108
    I have a leak in my liner somewhere within a 1" strip around the pool wall... I can NOT find it and not sure what to do, the water is a hateful green now cause I cant fill pool and keep it running cause the level drops all the time, see no water coming out around side of pool, any ideas on locating it or what to do?
    Overwhelmed
    Pool size: 15' X 48" AG vinyl liner, 5300 gallons, Hayward S166T filter and 1hp pump
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Re: Still have leak and can NOT find it
    Does the water continue to leak or does it leak to a point and then stop? Do you have any creases in the liner on the pool wall? Is this an intex pool? Have you tried a die test around all the seams?
    Love TFP? Become a
    TFP Supporter!
    Jul 2008
    Bucyrus, Ohio
    108
    it does stop at a point, i suspect its in the seam we are pumping below the spot right now so we can seal good while its clean and dry. No its not an intex pool a
    Overwhelmed
