Thread: question about FC level
    Jul 2010
    Mickleton, NJ
    229
    I'm currently keeping my FC at 8 ppm, since my cya is 70. I understand it is higher than others because my cya is on the higher side. Is this level safe for us though? I have young kids 18 months and 4 years and I just want to be sure this isn't going to be too harsh for their skin. I'm using 6% bleach and have stopped using pucks as of about three weeks ago. Am I better off replacing water and bringing cya level down so that I can maintain a lower FC level or are things fine the way they are?
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    38,526
    Re: question about FC level
    I just asked this same question only my CYA is 100+ and my FC was over 20 ... was told it was not a problem and we swam and had no issues with a 2 and 4 yo.
    What I typically have been seeing in the forums is that it is safe to swim up to the shock level ... which according to poolcalculator.com for a CYA of 70 is a FC of 20.
    Actually, the calculator says that your target should be between FC 5 and 10 ... so 8 seems to be good.
    I am sure others will weigh in and hopefully confirm my understanding
    EDIT: oops I had the target levels wrong ... now corrected.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    As long as your CYA is 70, and CC is 0.5ppm or below, PH around 7.4-7.6, you will be just fine. I run my pool between 6-8ppm all summer, and all my kids limbs are in tact, eyes are never red...etc. Neighbors love my salt pool instead of their chlorine pool
    Quote Originally Posted by dmanb2b
    My fiance told me her friend's brother switched to a "salt water" pool so their baby wouldn't be in chlorine!
    BLAST! I need to request a smilie. Same as Mr Green only spinning
    on a note related to this thread, my CYA is around 90-100, was at 100 probably closer to 90-95 by now. And I was planning to target my FC around 10-12, I'm still going strong from a shock, but probably need to bring it back up since my last test had CC @ 0.75-1ppm (believe I have it written down at home).
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Things are fine the way they are. You wouldn't want to swim in 8 ppm FC if you had no CYA. But they way it works chemically, you're really only at the equivalent of about .5 FC with no CYA. That's less than most municipal tap water has.
    70 is a little high, but certainly manageable. You won't be able to use the color matching tester to check FC, that's all. You must use the FAS-DPD test. I survived all last summer with CYA between 2 and 3 times as high as yours! Just don't let FC drop too low and get an algae bloom, shock level is astronomical then.
    Assuming you don't add any more stabilizer, even snuck in via tablets, expect CYA to go down with splashout. Might take til end of summer to show up on the tester, but it will gradually dilute.
