Thread: Yellowish Stain around water level
    mdrugbymom's Avatar
    May 2009
    5
    How do I remove a yellowish stain around the ring of the water level? I've tried brushing it, to no avail.
    We didn't "close" our inground pool last year, and this has been a nightmare trying to get it up and running.
    We started with a dark green slimy pool, and broken pipes, and after getting the pipes replaced, it's now on it's way to blue, but extremely cloudy, (so much so, that I can't even see the first step).
    I've been vacumming and sweeping, but it's hard to know what else is down on the bottom when you can't see!
    30,000 gallons, vinyl, inground pool, will post pics if that will help!
    Thanks for your help!
    14,000 gallon in ground plaster pool with Hidrazzo goulstrem blue finish with infinity edge and spillover from spa, Pentair challenger 1 1/2 HP filter pump, 2 HP Pentair challenger spa jet pump, Hayward 30" sand filter, Pentair IC40 SWG, Raypack 5100 heat pump, Jandy Aqualink PS8 controls, Kreepy Krauly
    22,549
    Re: Yellowish Stain around water level
    Post a full set of test results and how you got them.
    pH
    FC
    CC
    TA
    CH
    CYA
    You can try a Mr Clean Magic Eraser to clean the ring.
