Thread: When can you swim after Cal Hypo
    How long should you wait after using Cal Hypo to bring your chlorine level up to a normal level ..in other words not shocking the pool but merely adding a few ppm to bring it up to say 4ppm ..dissolved in a pail and poured in?
    Glenn - Pickering, Ontario
    Circa 1980 Vinyl In-ground 80,000 Ltrs. ~ K2006 Kit ~ Hayward Pump/Navigator/Sand Filter ~ Raypak 255 Gas Heater
    Aug 2010
    Dallas, TX
    4,052
    Re: When can you swim after Cal Hypo
    Immediately I would say. It's just chlorine and calcium. You might wait an hour for everything to get stirred around, sweeping will help, but I see no reason to wait.
    An hour is completely safe. Half an hour or less is probably fine, but that depends on how good your circulation is.
