Results 1 to 17 of 17
Thread: CSI of -0.48 to -0.61 - Should I be concerned?
    phalcon51's Avatar
    Oct 2010
    So. California
    203
    According to the Pool Calc app my CSI is somewhere between -0.48 to -0.57 depending on my pH, CYA and salt level.
    FC = 4.0
    CC = 0
    pH = 7.4
    TA = 70
    CH = 300
    CYA = 50
    Salt = 3280 (strips)
    Temp = 70
    CSI = -0.48
    or
    FC = 4.0
    CC = 0
    pH = 7.5
    TA = 70
    CH = 300
    CYA = 50
    Salt = 3600 (drops)
    Temp = 70
    CSI = -0.57
    and if I get my CYA up where I want it:
    FC = 4.0
    CC = 0
    pH = 7.5
    TA = 70
    CH = 300
    CYA = 70
    Salt = 3600 (drops)
    Temp = 70
    CSI = -0.63
    Is a CSI at these levels a problem? What adjustments should I make?
    Which is more trusted for the salt test, AquaCheck strips or the Taylor drop test?
    Gary
    26,200 gal. 35' x 16' Plaster IGP (50 yrs. old), Hayward 48 sq. ft. DE filter, Hayward EcoStar VS pump, Intellichlor IC-40 SWCG, The Pool Cleaner 4X suction, Pool Skim and Pool Devil skimmers. Re-plastered Sept. 2010.
    30,432
    Re: CSI of -0.48 to -0.61 - Should I be concerned?
    For the best accuracy and reliabilty, the Taylor drops test is better than the strips.
    That said, the strips are accurate enough to use with your SWG but they do have a shelf life.
    Just me, but I have NEVER had to consider CSI in my pool management. If you keep your parameters within the ranges suggested here, CSI is irrelevant.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    I'd raise your TA to 100 or something, unless it's a liner or fibreglass pool, then I'd leave it alone.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Hi
    I just fiddled with your numbers on the Pool Calculator, and it seems that if you upped your pH slightly to 7.5, your calcium to 350, and your TA to 90, AND with a pool water temperature of 80 degrees, you'd be at -.19, which is not too shabby for an SWG. (Trust but verify~~ )
    Your water temperature won't be staying at 70 for very long before warming up for the summer, right? Temperature counts a good deal with all this.
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    What kind of pool do you have? Vinyl, fiberglass, or plaster/pebble/quartz?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    The main issue may be temp ...just a guess this time of year, but I would think your water won;t stay at 70deg very long...if your water warms up 10 deg, your CSI should rise by about .1
    susa's Avatar
    Oct 2010
    Deep South
    578
    based on Jason's suggestions in another thread, I would keep TA closer to 50 and allow pH to climb to 7.7--7.8 as the MA demand will stabilize with a SWCG
    I keep TA at 60 and pH at 7.7 with the Simpool and am using hardly any MA weekly.
    phalcon51's Avatar
    Oct 2010
    So. California
    203
    Yes, I'm purposely keeping the TA at 70 to try and reduce the amount and frequency of MA additions. I try to keep the pH between 7.5 and 7.8 and I seem to be adding about 2 1/2 to 3 cups of acid every 3 or 4 days. I had the pool re-plastered about 8 months ago so that may still account for most of that. I'm hoping the plaster cures within a year and the acid use stabilizes somewhat.
    Gary
    The Taylor salt test is more reliable than the AquaChek strips, but it is still about +-400.
    I wouldn't worry about CSI much. Both the PH and the water temperature are going to come up noticeably from where they are now. If it makes you more comfortable, bringing CH up to 350 would be good.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    I had the same problem when I converted to SWG. After playing with the pool calculator, the simplest way to keep a decent CSI was to maintain a 7.8 pH.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    You want the PH at 7.7 or 7.8 anyway to minimize PH drift.
    phalcon51's Avatar
    Oct 2010
    So. California
    203
    If I did that I'd be adding acid daily! It only takes a day to go from 7.8 to 8.0 and beyond the next day.
    Gary
    Let TA come down and the PH will go up more slowly. Let PH go up, and it will go up more slowly. Add borates, and the PH will go up more slowly.
    By lowering PH below 7.7, you speed up the cycle of PH constantly rising.
    phalcon51's Avatar
    Oct 2010
    So. California
    203
    I've already lowered the TA to 70. Are you saying I should go lower? 60? 50? Is the acid demand still likely due to the new plaster from Sept. last year? If so, will the lower TA and/or higher pH still have a beneficial effect on the acid demand, or not until the plaster cures completely?
    Gary
    There is an acid demand from the plaster, which won't go away until the plaster finishes curing. There is also an acid demand from TA being above about 40 or 50. It is difficult to say have much of your PH drift is from which cause, only that they are both happening. Borates help slow PH drift from both causes, though borates never eliminate PH drift completely. Lowering TA and raising PH helps reduce or even eliminate PH drift from TA. You can lower TA to 60 without borates, or down to 50 with borates.
    phalcon51's Avatar
    Oct 2010
    So. California
    203
    Any downside or potential problems related to having the TA so low?
    Gary
    Not really. With TA very low you probably don't want to bring your PH down below 7.5, but there isn't normally a reason to do that anyway. Because of that you have a slightly smaller range for PH to swing from the plaster curing between acid additions, but the total time between acid additions should be similar or even longer, definitely longer if you add borates.
