Thread: Small Pool. Need suction cleaner?
    I have a 9000 gallon fiberglass pool. For the last year I have been mainly using my Pool Blaster Max to clean it and it worked great until like all of those units, mine failed. So now I am back to dragging out the hose and using the vac head to clean it.
    I am considering getting an automatic cleaner but have some questions and criteria.
    Pool Plumbed for options.
    My pool pad has a couple extra lines buried running to the pool that currently aren't plumbed to anything at the pad. I was told that they could be hooked up to a cleaner. I'm assuming it would be a return side cleaner since there is an extra (currently plugged) hole in the top side of my pool opposite side of another pool return.
    Should i invest in having this plumbed for return side cleaning or would it be worth it for such a small pool?
    Inexpensive
    My pool is small. I am young and I don't want to spend a lot of money. So i can continue to clean manually at no added expense but am exploring my options. I don't want to spend over $300.
    Dependable
    I just wasted $280 on a Pool Blaster Max purchased in April 2010. It is already dead and the company refuses to help me. They said, "tough luck," essentially.
    I want to buy a simple, dependable effective cleaner. One that will last for years to come.
    Suction vs. Return Power
    I once thought it would make more sense to use the return cleaner since that would leave my skimmer freed up to skim. But then I wondered if the hose for the cleaner would be lurking on the water surface making my skimmer largely ineffective any way. By this i mean, with a small pool and one skimmer at the end, will ANY hose cause debris to collect against it rather than finding it's way into the skimmer?
    Recommendations
    Can someone recommend a good cleaner that will meet my needs? Should I just forget it and stick with cleaning manually?
    Will I be frustrated regardless of what I buy in that price range?
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: Small Pool. Need suction cleaner?
    Is your pool flat bottomed, or does it have a deep end?
    Pool goes from 6' to approx. 3'.
    10,000 gallon
    NC KANSAS44
