Thread: What is the order for adding BBB?
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    Hi --
    Just need some clarification about the correct order/timing to add BBB to balance the water?
    Once that is done, then add dichlor (for my small pool size) to bring CYA up? Then wait a week and check CYA again? or when should it be checked after adding the dichlor.
    Still getting my head wrapped around the water chemistry / BBB method.
    Thanks.
    12'x36" / 2100 gal/ AG / Krystal Clear Model 603 filter cartridge pump ( cleans surprisingly well for a $35 pump!)
    22,550
    Re: What is the order for adding BBB?
    The first thing to do is test the water.
    Depending on the results of what to do next.
    If the pH is off take care of that first.
    Then the chlorine.
    You can work on the rest in no particular order.
    Don't worry about CH unless it's very high.
    Butterfly's Avatar
    South Carolina
    10,045
    As Bama said, test results first.
    Example: if your TA is very low, we may suggest raising that as the first step. Hence, test results.
    You're done SLAMing when:
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    Thanks will know what to do now!
