Results 1 to 7 of 7
Thread: Very high PH. Never had a issue when opening.
    Central NJ
    44
    Hi all.
    PH...off the chart must be 10+
    FC... I am shocking at 15+ppm
    Alk...90
    Cya..20
    OK opened pool. It was green as usual. Been shocking and running filter 24 hrs a day for about 2 days now. Water went from green soup to light green/blue/cloudy.
    The issue I never had high PH when opening the pool. Whats up with that?
    I do have last yrs test kits though. Tried the OTO and DPD with same results.
    What am I looking at here, and I guess I will not be ready for memorial day.
    I have been following BBB from day one, and this is really me first issue ever.
    12X18 AG, 6200 gal
    Hayward S166T sand filter, Switched back to 100 sq ft cart.
    Hayward 1hp power flo matrix two speed pump.
    Been using BBB since pool was new in 2004. Never had any problems.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Very high PH. Never had a issue when opening.
    If you're getting those PH high numbers while shocking............it doesn't mean much. It's naturally gonna check high when your FC is at 10 or better. You'll be fine! You should consider raising your CYA to at least 30 and shock for that level to help hold more FC during the process.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    High FC can distort the pH reading. Did you measure it before or after dumping all that chlorine in?
    The good news is, pH is easy to adjust. Once the pool is clear and the FC drops below 10, get your pH, plug things into pool calculator, and add the necessary acid. I'd brush things up good, it speeds up the mixing. In an hour or so, test again, and fine-tune.
    But keep the FC up, don't coast. You might just be able to get in by Monday!
    Central NJ
    44
    Quote Originally Posted by woodyp
    OK woody. I am going to hold you too it. We will see.
    12X18 AG, 6200 gal
    Central NJ
    44
    Quote Originally Posted by Richard320
    Yes I been testing with the Cl level up. I dont remember in all the other yrs this occuring, thats why I posted here.
    Yeah, I am not coasting. Possibly I should vacuum. I usually dont vacuum until I can see the bottom some what. Other wise I would be doing it blind.
    12X18 AG, 6200 gal
    Central NJ
    44
    Update....Re: Very high PH. Never had a issue when opening.
    OK, I took a vacuum to the pool and got some leaves out that must have fallen in when I took the cover off..
    Pool is a light greenish, blue, white haze. The water was pea soup.
    Got rid of the cart, (last yr) and have sand this yr. Its taking along time to clear up with sand. The cartridges are faster, but a PITA to clean. Especially when start up. Thats why I went to sand.
    I think my pump may be too strong for this filter. (got it on that list site. Replaced all inards.) Possibly its pushing all the crude right through. It starts at 12PSI and builds to about 18PSI and dont really climb anymore. Except when I add about 1/4 -1/2 cup DE it climbs to 20psi quickly. Probably catching all the crude, and thats when I backwash because the flow is real reduced at 20 psi.
    I tried putting a smaller hose at the skimmer to pump and pump to skimmer to reduce the flow. They look like 1 1/4 to me.
    I have the bigger hose 1 1/2 from filter to return. Anyway the pump to filter hose split and I put another bigger hose on I had. Ugg...I dont know.
    I think I will run the pump all night on low speed and see how it looks in the morning. OK let me go throw some bleach in..
    12X18 AG, 6200 gal
    Feb 2008
    Denton, TX
    5,061
    When your filter pressure rises like that during the process of trying to clear an algae bloom, it is because you need to backwash. I don't think that it has to do with a pump and filter mismatch.
