Thread: Lost my Blue Scooper for CL Test - TF Test Kit
    I just realized I can't find my little blue scooper to test my CL. Is there something else I can use? An 1/8 teaspoon? I know I have CL using the basic yellow dye reagent, it is the CC I wanted to test.
    I plan on placing an order for refills this weekend so I will be sure to add a blue scooper but in the mean time, any help is appreciated.
    Thx!
    18x36 IG Vinyl Grecian Lazy L (20k gallons) ~ Whisperflo DS 2.0HP pump ~ QuadDE100 filter ~ Autopilot SWG DIG-60 ~ (7) 4x16 solar panels
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Re: Lost my Blue Scooper for CL Test - TF Test Kit
    A popsicle stick?
    Sep 2009
    Frederick County, MD
    184
    It is somewhat of an inexact amount in that you nead a "heaping" scoop. A pinch should do until you get the scoop from Dave.
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
    30,420
    Yes, winger and Richard are both right. it is inexact. As long as the solution turns pink/red, it's good. If it goes to pink/red for just a second or two and then turns back clear, add the same amount of powder again.
    I would use the VERY tip of a popsicle stick, etc. YOu don't need very much at all EXCEPT that it really helps my refill sales when you GLOP it in there!!
    Thanks for all the help and I will keep the info for future use since I found it right under my nose! It was where it was supposed to be in my kit. Just one of those days!
