Thread: Replaced the cell (still get error code)
    I have an older model Autoclear Plus SWG that was gving me an error code 94.
    I just replaced the cell and the errror code is still registering.
    I cannot see any blown fuse to the controller.
    I do see a fuse to the transformer box but it is in perfect working order.
    Can the controller have an internal fuse built into the CPU board?
    I know my salt and pool levels are fine.
    any suggestions........
    12,000 gal. in ground pebble tech. pool with Hayward pump system.
    23,000 gallon inground free form pool with spillover spa, Paramount in floor auto pool cleaner, Hayward C17502 filter, Andrews Advantage Series heater, 2hp Pentair WhisperFlo 26 pump for in floor auto pool cleaner, 2hp WhisperFlo 28 pump for pool filter
    Pacifica's Avatar
    Mar 2010
    San Diego, CA
    47
    Re: Replaced the cell (still get error code)
    It looks like your cpu board could have gone out. What you should try is a Goldline SWG system. I only install this brand of SWG in the field. They are extremely reliable, low maintenance and easy to use. They also produce more chlorine than many other models on the market in comparable cells. Here's a link to one for reference: http://www.pacificapoolsupplies.com/...-power-center/
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    I have an AquaRite/Goldline SWG - the good thing is that all the parts are easy to find/replace if there are problems or as they wear out.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
