Results 1 to 7 of 7
Thread: Pool lights - needed or not?
    May 2011
    Bensalem PA (Philly Suburbs)
    82
    I'm going to be installing a 18' by 38' oval above ground pool with a 6' deep end. Are pool lights needed or recommended? I plan to use my pool in the evenings sometimes I'm sure, but I will have outside lighting. If lights inside the pool are recommended, any recommendations on what types or brands I should look into?
    18' x 38' x 52" oval AGP with 6' deep end (foam on the walls, preformed coving, and Happy Bottom floor padding)
    Pentair Optiflow 1 HP 2 Speed pump
    Pentair cc200 cartridge filter
    Pentair UltraTemp Model 110 BLK 108,000 BTU Heat Pump
    2 Intex SWG's (copper unplugged)
    Feb 2008
    Denton, TX
    5,061
    Re: Pool lights - needed or not?
    I would always recommend lights for a pool. For safety sake if not for asthetics as well.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,640
    If you have lights shining ON the pool...........may be all you need. Between the lights on my deck, a corner street light, the neighbors' security light and tiki torches...........you dang near need sunglasses! Installers put my pool light where I didn't really want it (half way down one side) which shined directly toward my house deck. The existing deck at the time was only 10 feet from the near long side of the pool. I never bothered to put it back on the far end shining lengthwise.
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by 257WbyMag
    +1
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    May 2011
    82
    So if pool lights are recommended... what exactly do I need to look for? How many? Are there different types? I'm guessing they should be installed before the pool is filled, so I will need to order them soon if I'm getting them... and I have no clue about them
    May 2011
    82
    Any recommendations where to start looking or what to look for?
    I've been looking at this one, but I don't know much about it other than reading reviews.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
