Thread: Pool cove quick repair question/Metal coming through liner?
    Mar 2009
    Woods of North Florida
    148
    We have had a small leak in our pool but have not been able to find it...until yesterday. It is at the bottom corner of the pool. There seems to be a metal bar and pieces of it stick up and made the small hole. You can feel about a six inch section of thin metal rod and the sand in the area seems to be gone (the liner dips down a little).
    What is the best way to fix this? Is it normal for this metal piece to be there? Thanks!
    24' Seaspray Evolution CLX Above Ground Pool (~13600 gallons)
    Pentair Sand Dollar SD60 / 22.5" filter / Maximum Flow Rate 60 GPM
    Pentair Dynamo Pump 1 1/2 HP
    Re: Metal coming through liner?
    That sounds like bottom rail without the sand "cove". While you might patch the holes until the missing cove problem is resolved it will likely happen again. I believe the only practical way to fully address that is drain, remove liner (full or partial) and correct it. If your liner is of some age it may be a bit brittle and fail completely if you try to remove it. You might cripple through the season with a patch and address it later. I have seen patch kits claiming to work under water but I have not (knock on wood) ever had occassion to try one.
    The last two pools I have done I went with the triangular high density foam cove. It was an added expense but it was very quick and easy to install compared to sand and has proven trouble free over 5 years for me.
    ____________________________________________________________ ________
    George (7500 gal AG, sand filter, way too busy not to have a Trouble Free Pool)
    Mar 2009
    148
    Oh dear. I really don't want to have to drain the whole pool and start over. It has only been installed for 2 years now. Is there any way to add sand to the cove area without taking out the whole pool?
