Results 1 to 11 of 11
Thread: Millions of tiny red bugs in and around pool and skimmer.
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    I need some help with the BUGS!!!
    To start off here are my pool numbers.
    FC: 6
    CC: 0
    TC: 6
    PH: 7.5
    CH: 180
    TA: 80
    CYA: 70
    I have millions of these very tiny red bugs all over my skimmer, in the skimmer, in the water, and flying around all over. They hurt when they bite and just down right ichy. Does anyone know what they are and how to get rid of them? I will attach pics in a few.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    susa's Avatar
    Oct 2010
    Deep South
    578
    Re: Millions of tiny red bugs in and around pool and skimmer
    do they look like these
    crookm11's Avatar
    Jun 2010
    422
    Pics of BUGS!!!!
    HELP!!!
    Mark Crook
    Aug 2010
    Dallas, TX
    4,052
    I had about a billion of those (although VERY bright red) around my pool earlier this year. I figured they were some sort of mites. They went away on their own for me.
    LauleaHere&There's Avatar
    Aug 2010
    Rural Moloka'i, Hawai'i
    155
    Considering the time of year, they could be clover mites. http://ohioline.osu.edu/hyg-fact/2000/2095.html
    12' round above ground pool. 3,500 gal. Vinyl liner. Waterway Supreme Hi-Flo 48 frame pump. 1.5 hp. SWG. Sand filter with Zeobrite.
    Thanks, members of Trouble Free Pool, for being so friendly and informative!
    Dec 2009
    Central Massachusetts
    2,690
    They're red spider mites.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    t2roadrunner's Avatar
    Jun 2011
    Senatobia, MS
    30
    We just put our pool up today and it only has about 4 inches of water in it so far, but those little red bugs have appeared...YIKES....they hurt....and they look just like the ones in the pictures someone else did such a great job taking. Soooo...will they just go away by themselves....there weren't so many on the top rail but when I looked around the bottom of the legs, there were quite a few more!
    Any help/suggestions are greatly appreciated!
    Intex Ultra Frame AG
    16' x 48" - 5061 gallons
    Krystal Clear Filter Pump
    Model 635T - 1500gph
    Cartridge A (59900)
    Krystal Clear Saltwater System
    Model CS8110
    RE: Millions of tiny red bugs in and around my pool.
    I have same problem, these tiny red bugs have wasp like bodys under microscope, and they fly, they are not spider mites, spider mites do not fly. does anyone know what these are? and how to get rid of them, i cannot swim without being biten/stung by these little buggers. they float on top of the water for hours alive, some appear to have drowned. i am trying to take a picture thru microscope but not any luck yet.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Maybe adding borates to the water might help. I've read that it is a mild pesticide. Just something to try.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    Jul 2009
    Olney, MD
    218
    Quote Originally Posted by guamguy
    I make a "simple syrup" out of borax, sugar and water that seems to keep my local ant population under control, I dip cotton balls in it and place them in containers around the pool. Maybe a similar solution (minus the sugar) in a spray bottle would get rid of some (and add some borates to your pool water).
    I don't know how effective borates in the pool would be because the concentration would be so low, but a higher concentration in a spray bottle might do the trick. I have water spiders that are still alive in 16 ppm chlorine, but I bet a few squirts of mildly diluted bleach would do them in!
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    Jun 2015
    Riner, Va
    1
    How can I see any replies to these posts?? We just discovered the same problem and don't know what to do. Thanks!
