Thread: TA/PH confusion....please help
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    We are just starting our third year with TFP and so far it has worked wonderfully. I want it to continue to work wonderfully, hence, I need clarification on the PH/TA relationship. For some reason, I have a big mental door shut on this one and am having a hard time coming to terms with what I need to do, what to use and in what order.
    Here are my numbers from 5:30pm:
    FC 4.5
    CC 1.0
    TC 5.5
    TA 130
    PH 7.2
    CYA 40 (I finished squeezing the dry CYA out of a sock yesterday and watched it float away into the H2O
    Water temp 74
    I understand I need to put in enough chlorine for shock as I have something chewing/attempting to grow in there.
    Here is what the pool calculator tells me to do with the TA and PH (I love the calc btw)
    (My PH is currently at 7.2)
    It says to add either washing soda or borax if I want to get my PH to 7.5
    *Note: pH calculations depend on TA and Borate. Results are approximate and can be off significantly for large pH changes. Changing your pH will also change your TA.
    TA(currently at 130...up from yesterday's rdg of 120)
    Goal: 70 to 90
    *To lower TA you reduce pH to 7.0-7.2 with acid and then aerate to increase pH.
    Note: Adding baking soda will also raise your pH.
    *directly from the calculator.
    Please give me direction with this. The pool has been filtering for about 3 hours and the return is allowing the water to break the surface of the water in the pool.
    The water is crystal clear and sparkling!!! Another victim of sparklypoolitis
    Thanks for any info you can give me.
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: TA/PH confusion....please help
    Are you wanting to lower TA more? What targets are you shooting for?
    Love TFP? Become a
    TFP Supporter!
    Just leave your PH at 7.2. There is no reason to raise it to 7.5, as it will drift up on it's own.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Listen to what your pool is Showing you. You may be just fine with TA at that level. Mine was at around 170 all last summer no major PH problems. Your PH is fine cause its probably gonna rise on its own. I'd say shock it to eleminate the CC @ 1.0 but that may not even be necessary. I'd bump the old chlorine up just 3 or 4 points and see if it clears with the help of some sunshine. Mine has done that a lot.
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    thanks. I'll bump my FC up to about 9 or so and check it again tomorrow.
    supposed to rain here tomorrow...gosh...what a novel thing, rain in NE ohio this spring. gag me. I am so sick of rain that I ....well, I will save that for another post!
