Thread: Black Rubbery Strip Between Stairs & Liner Peeled Right Off
    Today in my pool, I noticed a black rubbery thin strip that I presume was acting to prevent water from entering between the stairs and the liner peel right off on both sides of the stairs. It was a very thin black strip. Should I be concerned? I have noticed that my water level seems to have dropped slightly since yesterday despite colder weather, no heater being on, and the pump running minimally. I will perform the bucket test later this week but curious if I should be concerned about the fact that both of these black strips peeled right off.
    Thanks
    27x14x6 IG Salt Water Pool
    Raypak 206 NG Heater
    T-Cell-9 Super Chlorinator
    Hayward Tristar 1/2 HP Pump
    Aqua P4 Logic System w/AquaPod
    Cartridge Filter System
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Black Rubbery Strip Between Stairs & Liner Peeled Right
    Those are the gaskets that seal the faceplate. You can try tightening the screws to seal the faceplates, but you do kind of need them to keep the seal.
    Let me just ask a quick question, how large were the strips that came off? (if they were ~ 1/8" it's just the overlap that came off, if they were 1+", the entire gasket came off.)
    Luv& Luk
    -Ted
    They were 1/8th of an inch at most. Very thin strips, one on either side of the stairs where the vertical columns keep the liner in place. I presume then that there's an inch of this rubber seal underneath those vertical columns?
    Thanks
    Quote Originally Posted by waste
    Mar 2007
    4,160
    You got it
    Luv& Luk
    -Ted
    Beauty. Thanks
