Results 1 to 11 of 11
Thread: too much chlorine please help
    pool store test showed 1.07 total cl, 5.17 ph and he said alkalinity was low,
    i listened to him, added 8 pounds of "sun black algae" treatment and 10 pounds of ph up 7 days ago.
    i tested today and
    i am showing on my tester a free chlorine of 35ppm, CC of 0 a full 7 days after adding the shock/algea treatment using my new taylor 2006 kit. my ph is high but i read that it is normal when you have a high cl load to show a high ph.
    ALK is showing 200 on my test.
    his digital machine still shows that my cl is low. ph is 7.7 and alk at around 50
    what do i need to do to get the cl down so i can get reliable test?
    23000 gallon fiberglass pool
    hayward pro II sand filter with 1 1/2 hp motor and pump
    SWG aqua pro, dolphin diagnostics advantage robot
    Re: too much chlorene please help
    You can get a chlorine reducer, typically sodium thiosulfate, but is there any reason you are in a hurry to get the FC level down?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    I think I would take a sample to another pool store to check. Your pool store's results look suspicious to me and I think a 3rd opinion is called for. Also what are you using to test with at home?
    Love TFP? Become a
    TFP Supporter!
    i have a taylor 2006 test kit,
    I am thinking that the pool store test machine cant read the high cl level and so it is showing low.
    I am not really in a hurry just dont think i am getting readings that are correct with the cl at 30ppm+ how long should it take with my SWG off to get the cl levels down to a reasonable concentration from the 30 they are now?
    i am in oklahoma and the temps are in the 80 during the day and 50s at night, water temp is 74
    30,421
    That depends on your CYA level...post it up and we can get a good guestimate.
    CYA 110
    30,421
    Assuming your pool gets full sun and you don't live in Alaska I would guestimate that it'll take about 8-10 days for your pool to get down to less than 10ppm.
    On a side note, your CYA should be reduced.....110 (How did you test that?)is doable but I wouldn't put up with all the issues it brings. About 60-80 is ideal for an SWG pool.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Quote Originally Posted by trent1059
    I bet the super high FC is bleaching out the test strips they're using!!
    May 2011
    2
    Re: too much chlorine please help
    Your CYA definitely needs to be reduced, The cyanuric acid lowers the effectiveness of the FC. Your ideal numbers would be between 30-50. To be honest with you, the only practical way to lower your CYA is to replace water. Good luck to you!
    ___________________________________
    Pool chlorine , the breakfast of champions!
    Quote Originally Posted by ljacobs1987
    LJ, you missed that he has a SWG, so the CYA level that is right for him is higher than you suggest.
    May 2011
    2
    You are right! I agree.
