Thread: Booster Pump
    Booster Pump
    My booster pump is not working properly. The motor seems to be running just fine, however, I do not get any increased pressure at the cleaner outlet. Any suggestions?
    13,000 gal gunite/pebbletec pool/spa, pentair FNSplus DE filter, Whiperflo pumps, Jandy Aqualink/PDA, gas heater, Polaris 360, Nature2, DelZone Eclipse 1
    Builder: Anthony Sylvan Charlotte, 2009
    22,551
    Re: Booster Pump
    Have you checked the impeller for blockage? How about the plumbing?
    Is it tied into the main pump discharge?
    Re: Booster Pump
    It was working fine until recently, so nothing has change in the plumbing. The pool has been somewhat unattended so I am concerned about plugging.
    How do you check the impeller for clogging?
    22,551
    Re: Booster Pump
    You can disconnect the piping and run a water hose backward through the pump (in the discharge and out the suction.) Look for any debris that becomes dislodged and flushes out the suction. If that doesn't work you'll have to look into the suction end and see if there's anything in there. An inspection mirror might make it easier.
