Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: What is the best way to raise the CYA?
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    Hi all - I also have a CYA question. My pool has been up for a week and it's looking good! I got my test kit from TFP and the first time I tested the CYA, it registered <20, CL - 1
    pH - 7.4
    CYA - <20
    12'x36" / 2100 gal/ AG / Krystal Clear Model 603 filter cartridge pump ( cleans surprisingly well for a $35 pump!)
    Re: What is the best way to raise the CYA?
    For a small pool you often want to raise CYA using dichlor, as described in your seasonal pool guide. For larger pools it is more common to use cyanuric acid, often sold as either stabilizer or conditioner.
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    Thanks - I'll review that section again to raise the CYA.
    Feb 2008
    Denton, TX
    5,061
    Dichlor is good because it dissolves quickly and adds FC as well. It's also available at most places in single use packs.
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    So tonight I checked the water :
    FC .5 - added bleach as per The Pool Calc
    pH 7.2 - added borax as per The PC 30 mins after the bleach
    CYA - <10 - I have some Aqua Chem Shock Plus Stabilizer
    So how long do I wait to add the Shock Plus per PC ?
    Feb 2008
    Denton, TX
    5,061
    What are your test results currently? FC, CC, pH, TA, CH. Already know your CYA. If you have CC > .5, you might could just go ahead and shock with your dichlor.
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    What is the length of time in between treating the pool - 30 mins. 1 hour overnight - How long should the pump run....my dinky pump would probably burn up if I leave it on 24/7 in the hot sun.
    Feb 2008
    Denton, TX
    5,061
    With the pump running, you are safe to wait 30 minutes between chemical additions. As far as routine pump run times, it all depends on how long it takes for your pump to turn the water over. I run mine 4 to 6 hours a day in the summer. it is always on whenver there are swimmers in the pool.
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    So - my chlorine has been lasting for a couple days at a good level then it will drop down to .5. pH is stable at 7.5 most days. CYA is <10 but according to what read in PS the way shock my size pool is with bleach. So then if I don't use Dichlor, how do I raise the CYA?
    CYA Cyanuric Acid (Read pool school!!) sold at wal-mart as Stabilizer or conidtioner...
    use pool calculator to calculate dosage for your pool. Do the dosage in steps to ensure you don't unintentionally get a higher CYA than you want. CYA can take a week to fully dissolve so don't rush to add more if you think the test is still low (highly subjective test for CYA) Once you have too much the only way to get rid of it is Water replacement
    Read Pool School thru the link at teh top of the screen!
    24' Round 54" Impulse Ovation AGP, 1.5 HP 2 Spd, 150 Sq Ft. Cartridge Filter, RayPak 130K BTU NG Heater, BBB in full effect!!
    Vist TFT Test Kits --- Visit Pool School ---
    Visit the Pool Calculator
    Feb 2011
    Bakersfield, California
    23
    Quote Originally Posted by Red Shirt Ensign
    How exactly is that conditioner supposed to be applied to the pool? When I've added it to the water in the past. It just sinks to the bottom and never dissolves. I vacuum it up and then it clogs the filter.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    old sock, rubber band, tie off to ladder. Then come by every couple hours and squish the sock and let the softened powder disperse. Use the pool calculator to determine how much stabilizer will add 20ppm of CYA to your pool. That should get you up to about 30ppm which is low for super hot climates but also a good starting point until you can get an accurate reading for CYA. Then, assume you have 30ppm CYA in the pool and set the pool calculator for that number. Remember, adding CYA will change your target, minimum and shock levels to min 2, target 6, shock 13 whereas without CYA you're looking at 1, 3, and 10.
    Run your pump full time. It won't burn up, it has water in it. With these small pools and inefficient pumps, filtering is very important. I actually run two Intex/seasonal pool type pumps on mine. Full time. They are both 1000gph pumps. One sucks at the bottom of the pool, one is on the skimmer. Works for me till I decide to invest in a better pump/filter.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Yup, powdered stabilizer in the sock. I use triclor tabs to add CYA when I do my monthly "store test" since my kit doesnt test CYA, in fact just store tested today.
    A month ago the CYA was 30, now it is 25. I'll pack my type A/C filter with 1 inch tabs two/three times, then switch back to bleach when I see the FC drop..
    CYA is an important test, but only gets critical when it is too high or too low. Too high binds your chlorine causing needs to keep a higher chlorine ppm. Too low, your chlorine burns off in the sunlight and doesnt kill the green meanies.
    As far as I'm concerned, with these Intex pools daily use is preferred and constant pumping are mandatory due to the lethargic flow.
    Feb 2011
    23
    Thanks for the responses folks. Good info there. Much better than having stabilizer on the pool bottom to get in-between my toes.
    I just bought a 637 Intex pump to replace the weak 603 pump that came with my 12' AGP. That should give me twice the gallons being filtered and will help keep things clearer.
    May 2011
    Clearwater, FL.
    446
    I did have the 637R pump with my pool (have upgraded to a Waterway sand filter system now) I did run it for 2 seasons 24/7 and still works good as I keep it in the garage for a spare should I need it.
    These 637R pumps also have a overheat protection system built in so they just shut down when you have a problem like once I did when a hose split and pool drained down and pump ran without water and automatically shut down.
    All I did was get new (better) hoses, refill pool, adjust pool balance and unplug pump for 15 mins. and it automatically reset and runs perfect again.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Feb 2011
    23
    Quote Originally Posted by supertune
    Yeah Chuck, I'll probably go that route next summer. I know the vacuum suction will be awesome in comparison to these little Intex pumps.
    Feb 2011
    23
    Quote Originally Posted by frogabog
    That's exactly what I did. It's amazing how a little bit of stabilizer will retain the chlorine levels.
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    So let me make sure I understand about adding diclor from the shock packets....I need to empty the amount indicated by the Pool Calculator into a sock and hang it from the pool ladder. After a couple hours, go to the pool and squeeze the sock to put the dissolved diclor into the pool. Correct?
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Dichlor is chlorine plus stabilizer (cya). It can be broadcasted.
    Stabilizer is hung in a sock, but it's not the same product as dichlor and if you're trying to raise CYA with dichlor alone be sure not to use the numbers for stabilizer in your calculations.
  20. Back To Top    #20
    Last year as I was learning the BBB method but using packets for shock, I would dip about 4 gallons into a 5 gallon bucket and put 1/3rd of the packet in and mix well, then pour in. Repeat twice.
    Straight granules on the bottom can bleach the surface.
