Thread: I lost my installation instructions - edit
    Well, I'm sure it's around somewhere. But for the life of me I can't find them! I'm having no luck looking online either. I called the place where I bought my pool and they gave me two email address that don't work. Maybe one of you could help me?
    Its a Sandy Point above ground pool (18x34 oval). From what I could tell it is made by artisan pools.
    ETA: Opps, I meant sandy point.
    22,537
    Re: I lost my installation instructions
    I did some searching and can't find that particular model and manufacturer. The place you bought it from should be able to copy a manual from another pool for you.
    Re: I lost my installation instructions - edit
    Heeeelp! They are no help where I bought the pool, the warehouse is seperate than the store. I can't seem to get them to pull one out. I'll try again later, and maybe I'll get someone more helpful.
    Feb 2011
    Sicklerville, NJ
    80
    I found the address for a pool manufacturer called Artesian Pools LLC as 1601 Wicomico St. in Baltimore.
    From that I found this http://start.cortera.com/company/res...ian-pools-llc/
    Which links to here: http://www.splashpoolsandspas.com/index.cfm
    And finally: http://www.backyardleisurepools.com/installation.html
    Don't know if that's the right one, but worth a shot.
    25k gal Lazy-L, vinyl liner, poly walls, swimout spa, diving board, TurboTwister slide.
    Hayward 2HP 2-spd pump, Pentair 2HP spa pump, Hayward 30" 500lb sand filter.
    Goldline Pro Logic PS-8 automation/SWG. 2 LED ColorLogic 4.0. 8 Jandy deck jets. MX-8 cleaner.
