Results 1 to 8 of 8
Thread: What is a sequestrant?
    Split into a new topic. If you hate to hijack then don't. JasonLion
    Ok...hate to hijack the thread, but what is a sequestrant? Can't find it defined in the pool school area (abbreviations and definitions area) , common chemicals, etc. Even the "start up" procedures for a plaster pool recommend early on to add a sequestrant, but what is a recommended one, and how much of it should I add?
    confused as usual....
    RawhideKid
    Phoenix, AZ (Goodyear actually)
    Pool finally complete!!! IG, 40,635 gallons w/2080 gallon spa with 16 jets. Pool is 40x21 ft with 10 ft deep end; two baja steps
    Pentair Cartridge filter - 520 SQ. PebbleSheen interior. 2 Pentair VS pumps. Pentair Intellichlor SWG
    4 deck jets, 2 bubblers, fake rock grotto/waterfall with wet steps. 3 surrounding half-pergola's with misters in future
    Sunken covered ramada with cabinets, fridge, and wood fireplace. (soon to have big screen TV)
    Basically, 14 years of planning on how to survive this blistering AZ summer!!! WAHOOOOO!!!!!!
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: New Saltwater Pool, proper birthing order?
    Quote Originally Posted by RawhideKid
    See Metals in the Water and Metal Stains in the Pool School. A metal sequestrant holds onto metals to prevent them from staining pool surfaces. It's only needed if you've got metals (iron, copper, manganese) in your water, such as sometimes occurs in well water.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Always be sure it is added BEFORE chlorine or it will oxidize the iron in the water and look like chocolate! First hand experience.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Quote Originally Posted by chem geek
    Ok - just read that link. How do you know if you have metals in your water - other than waiting for the stains to appear...
    and, if you are going to add a sequestrant to the water BEFORE chlorine (thx NWMNMom), how long do you wait to add chlorine after you put the sequestrant in? Hours? Days? I like chocolate, but, er, not in my pool....
    RawhideKid
    Re: What is a sequestrant?
    If you don't current have any reason to believe there are metals in the water then assume there aren't.
    Wait about four hours after adding sequestrant before doing anything that will raise PH or FC.
    Thanks Jason - you might want to adjust the plaster startup discussion as it seems to recommend sequestrant as part of the plaster pool start up procedure: pool-school/pool_plaster_start-up
    Given we have city water, and i've not heard of metals being an issue, we should be ok. Sorry to pick some nits, but i'd hate to have metal stains in my new (!) pool!
    RawhideKid
    For a fresh plaster startup you should add a sequestrant optimized for calcium even if there are no metals at all. There are two reasons for this. First, calcium is technically a metal, and sequestrant will help prevent calcium scaling, which is a big risk during a fresh plaster start up. And second, metals stains in the first week become permanently embedded in the plaster and can not be removed. Because of that you want to make extra sure even if the test were to show zero metals.
    Ah. Ok. Now I get it. Thanks!
    RawhideKid
