Jasonlion, I have the same issue with PH going up due to SWG pool and I run my pump 24hrs a day using Pentair VF pump, set the gallons of pool and how many turnovers per day and it run my pump at 40% and I have the SWG set for 30/35% since I run two SWG's. My CYA is at 0 currently need to add cya achieve 60ppm. My water is always crystal clear but PH creep is a killer. Your saying I can keep PH creep to a minimum by using borate, what type and amount. My chemical cost is just buying muriatic acid and salt when needed during the season. Any help would be great
Rich
FC 3
PH 7.5 was at 7.8 added 2.5gal of acid to bring down.
CYA 0 need to add 28lbs to increase to 60, filled with well water
Rich
FC 3
