Thread: CYA undetectable...can I add this?
    Here are my AM numbers after 2 days of round the clock filtering and lots of 6% bleach.
    FC 3
    CC .5
    pH 7.2
    TA 90
    CYA undetectable
    I know I don't want CYA high - had that issue last year but am thinking I need to raise it some to have bleach work. I have a small bottle of stabilized chlorinator for my spa that is 100% sodium dichloro s-triazinetrione dihydrate. Can I use that to raise CYA a bit and how much do I use for 30k gallon pool?
    Also, even though chlorine degrades during the day in sunlight, I keep adding it every hour to keep at shock levels until the water clears - is that correct?
    Thanks for the help guys - love this forum.
    Sus
    ____________________________________________________________ _____________________
    Vinyl free form IG 30,000 gallon pool
    Hayward S270T Pro Series High Rate Sand Filter
    AO Smith 1081 Centurion Pool Pump
    Sliding Board
    TF50 Test Kit and Taylor Ph test kit
    Aquabot Tempo
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: CYA undetectable...can I add this?
    Yes, it will raise CYA and FC. Use The Pool Calculator to figure out how much to use to raise the FC and CYA. Scroll down to the bottom of the page for the "effects of adding chemicals" section. Yes, keep the pool at shock level until the process is completed.
    Love TFP? Become a
    TFP Supporter!
    30,432
    You need SOME CYA in your pool. Your FC is being consumed by sunlight without it.
    Dose enough in there to get to 30ppm. If you don't know how much that is, use the Pool Calculator or post back and we'll help.
    You will struggle with your pool all summer if you don't introduce some CYA.
    How does your water look?
