Thread: Capacity of 8 gallon Liquidator
    DonW's Avatar
    Jun 2008
    Central IL.
    96
    What is the effective capacity of an 8 gallon Liquidator? Is it 8 gallons of bleach or is it a combination of bleach and pool water that equals 8 gallons?
    18' x 33' AGP
    16,715 gal.
    200 lb. Sand Filter w/Hayward PowerFlo MATRIX 1.5 H.P. 2 Spd. pump
    Stenner Injection Pump System
    Dec 2010
    San Diego, CA
    1,137
    Re: Capacity of 8 gallon Liquidator
    I believe it is 8 gals of bleach or Full strength CL
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    22,553
    It's 8 gallons of bleach. The unit when full will hold about 15 gallons of bleach and water combination. I've actually got about 10 gallons of chlorine in it. There's a piece of pipe on the fill funnel and they recommend not filling the bleach above that.
    Aug 2010
    Dallas, TX
    4,052
    The instructions that came with mine siad not to fill beyond where the black funnel turns to a white tube.
    Dec 2010
    San Diego, CA
    1,137
    So are you still using the LQ?
    22,553
    No, I'm using a peristaltic pump now. I gave the LQ to my sis and she's using it.
    There's a long thread about me and my peristaltic pump switch.
