Results 1 to 7 of 7
Thread: HELLLPPPPP!
    Dayton, Ohio
    79
    HELLLPPPPP!
    I was tired tonight and not thinking straight---put in too much CYA. I immediatley realized my mistake when I went to write the numbers down and took the sock out of the pool. Knew I needed to halve the amount (not fun when wet--a complete freakin' mess!) Put the sock back in the pool. Now, what in the heck do I do with the leftover WET CYA??? I looked at the MSDS sheet and it really did not help. It is about 1.5-2# dry CYA that is wet and soggy.
    AG Intex Ultra Frame
    Round 16 ft x 48 in, 5061 gal
    2500 gph Intex Krystal Clear Cartridge Filter
    BBB
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: HELLLPPPPP!
    Let's wait for chemgeek to reply!
    But off the top of my head, I'd say, bury it in some weedpatch corner of your yard and let it biodegrade into ammonia. You'll end up with some thriving bushy weeds!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: HELLLPPPPP!
    Will it kill fire ants? if so.....send it to me!
    Dayton, Ohio
    79
    Re: HELLLPPPPP!
    I called the non-emergency fire department and they had no idea. The lieutenant told me to put it up somewhere and cover it and call the solid waste district tomorrow! MSDS sheet online said NOT to cover it if wet. We have hazardous waste drop off in our county, but it was until (sigh) 4pm TODAY! Chemgeek, I hope you are online soon!
    BBB
    Re: HELLLPPPPP!
    If you leave it outside somewhere where it can dry off you should be able to rescue most of it. But you don't want the run off going into the ground. Try putting it in a basin or bucket but held up off the bottom so it can dry out.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: HELLLPPPPP!
    If it doesn't dry out or you want to get rid of it, then the following is typical of most MSDS for Cyanuric Acid:
    WASTE DISPOSAL:
    If this product becomes a waste, it DOES NOT meet the criteria of a hazardous
    waste as defined under 40 CFR 261, in that it does not exhibit the
    characteristics of hazardous waste in Subpart C, nor is it listed as a
    hazardous waste under Subpart D. As a nonhazardous solid waste, it should be
    disposed of in accordance with local, state, and federal regulations by
    disposal in a secure chemical landfill. Care must be taken to prevent
    environmental contamination from the use of this material. The user of this
    material has the responsibility to dispose of unused material, residues and
    containers in compliance with all relevant local, state and federal laws and
    regulations regarding treatment, storage and disposal for hazardous and
    nonhazardous wastes.
    You can always take it to your local garbage dump that has a hazardous waste facility and tell them what it is. They may just have you dump it with regular landfill, but that's up to them and they'll know the local regs (and can look it up, if necessary). It's toxic in concentrated form, but soil bacterial will love it and use it as a food source producing ammonia (actually ammonium ion which is more prevalent at lower pH) that will be taken up by plants, but only if this CYA gets well diluted.
    Dayton, Ohio
    79
    Re: HELLLPPPPP!
    Our county solid waste district has told me I can keep it in the garage, uncovered or covered, until I can take it to the next hazardous waste disposal (on Saturday). Thanks for all your advice!
    BBB
