Thread: Raypak 336A won't ignite
    Hi,
    Hoping some can help me troubleshoot my Propane heater - Raypak 336A.
    Each year when I start up my pool I have trouble getting the heater started (it's only 4 years old). But other years, keep trying and it eventually starts. This year I've tried several times and it will not start. At first, I hear a loud click (sounds like a relay), then the display goes from CFH to SPK. When it goes to SPK, I can hear a faint buzzing sound. It cycles like this for a while then the display shows ILO. I have to then re-power the heater to start again.
    My propane tanks are at 22% (haven't filled yet this year) and all the valves are on. I am thinking that gas is not getting to the pilot as maybe there is a clog somewhere. I don't know how to dismantle the unit to check this out. Are there any specific parts I should try to clean out? Should I remove the pilot and check it? I am usually pretty handy and not afraid to take this thing apart if I need to. I just really don't know what to check.
    I don't feel like calling the pool company if it could be something as simple as cleaning some debris. Anyone have any ideas on where to start?
    Thanks
    TF-100 Test kit, 24,000 gal. free form Vinyl. mybluepool AC-600 SWG, STA-RITE S7MD60 DE filter, 3/4 HP STA-RITE MPRA6D pump, Polaris 280 w/booster, Raypack Propane heater, Looplock mesh cover; All located in New England.
    Re: Raypak 336A won't ignite
    Nevermind.....I noticed there wasn't a spark at the ignitor, so I got out the schematic and found that the wire from the PC board to the ignitor wasn't making contact. When I close the pool, I always remove the PC board for the winter. Evidently, when I put the PC board back in I didn't connect that wire properly.
    Oh well.....at least it was an easy fix.
