Results 1 to 11 of 11
Thread: Help clear my green pool
    Jun 2008
    alabama
    6
    Ok, trying to turn my pool back into a sparkling oasis!
    Using the TF100 kit, these are my readings:
    FC-4 parts per million
    Ph- 6
    CC-2
    TA- 10
    CH- 200
    CYA- 50
    These readings are for a 30,000 gal IG pool with a vinyl liner. We have a sand filter.
    This problem occurred after the tornados that came through AL. Pool was clear prior to the storms, but since we have had green water. Approximately two weeks. Started yesterday with chlorine. Added total of 2400 ounces since 3 PM yesterday. We have also been brushing the pool and running the filter continuously. Water is still green and is not holding a high level of chlorine. What do I need to do now?
    24 ft. AG Jacuzzi pool, 52" high, 1.5hp Flo-Pro by Jacuzzi sand filter
    Deck coming soon!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,729
    Re: Help clear my green pool
    Are you sure you added Chlorine and not Muratic Acid? TA of 10 and PH of 6 is bound to cause damage to your pool surface. PH needs to be raised with Borax to 7.2 promptly. How did you measure PH of 6? The TF100 only goes down to 6.8
    Once PH is back in line, you will need a lot of bleach/liquid chlorine. Sorry to hear about the trouble the storms caused
    As dmanb2b said, you need to get the PH up to at least 7.2, then continue shocking.
    Jun 2008
    alabama
    6
    Checked #'s and PH was 6.8. I used liquid chlorine (bleach 6%)
    One thing that I did realize after reading some more posts, was that instead of adding the bleach all at one time, I added a little at a time over a 24 hr period. Going to try this again over the weekend. Thanks guys!
    Deck coming soon!
    Make it a priority to work on getting PH and TA at least roughly in range You want PH between 7.2 and 7.8 and TA between 50 and 90 for now. Chlorine is sometimes ineffective when PH and TA are too low.
    Then try raising FC to shock level, around 16 to 20 when CYA is 50, a couple of times a day.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Remember, pH will read wrong at shock levels, so you need to get it right before you start shocking, and then ignore it until shocking is done.
    Jun 2008
    alabama
    6
    Thanks so much guys! I will let you know how it goes!!
    Deck coming soon!
    Jun 2008
    alabama
    6
    Started late yesterday afternoon with my shock after getting my Ph levels and TA in the acceptable range. Checked my shock levels every half hour then hourly and only had to add minimal chlorine to keep it high. This morning levels had dropped from 20 to 17, pool still had some green spots but after brushing it is now a murky blue. I am seeing progress but will continue to monitor chlorine level closely today. Thanks so much !
    Deck coming soon!
    Butterfly's Avatar
    South Carolina
    10,045
    Sounds like you are getting things under control!
    Can we see a pic of your pool?
    Welcome to the forum
    You're done SLAMing when:
    Jun 2008
    alabama
    6
    Still not sparkling, but getting there!
    Deck coming soon!
    Richard320's Avatar
    Jan 2010
    18,967
    Hey! It's not green!!
    Keep the FC up and the filter running, and go away for a couple hours. A watched pot never boils and a watched pool never clears.
    Do not get complacent, though.....run the shock process until completion, including that annoying overnight loss test.
