Results 1 to 16 of 16
Thread: Leaves in bottom of Pool, will it clear
    Mar 2011
    North Carolina
    34
    Will the pool clear enough to where I can see to vacuum, I have been scooping for a few days off and on. I think I have the mojority out but the pool just want clear so Ima thinking its because I might have more than I think.
    Foxx Pool Grecian 27000 gallons (vinyl liner)
    Sand Filter w/ 300 #'s of Brand New Sand 6/3/11
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Leaves in bottom of Pool, will it clear
    Test results?
    Mar 2011
    North Carolina
    34
    CYA is not gonna read it was 0 at Pool store so I am putting some in as we speak gonna throw some schlorine in a bit and test an hour later hopefully it will be dark enuff and the chlorine will work at night alot better. But I am gonna get a sample and post some numbers but earlier numbers were
    FC 3
    CC .5
    PH 7.5
    Alk 60
    Calc 90
    Pool Store CYA 0
    after this reading I bought back up to 15 fc
    Feb 2008
    Denton, TX
    5,061
    What does the water look like?
    Mar 2011
    North Carolina
    34
    Lime cool-aid
    Gonna take a pic brb
    Feb 2008
    Denton, TX
    5,061
    Might be a good time to go ahead and really hammer the pool overnight by bumping to FC up considerably with bleach. Since you have no CYA in the pool now and the sun is down (no UV rays to burn your FC off), you can make some headway rather easily. This is assuming of course that you are able to run your pump and filter water and you have the time this evening to dedicate to it.
    Mar 2011
    North Carolina
    34
    shallow end
    deep end
    also shallow end steps
    Mar 2011
    North Carolina
    34
    Been above a free chlorine reading 0f 15 all day so far going to check it now,
    also I am running about .5 cc, so still work to be done, I will post a pic around 5:00 of my progress, any comments/advice
    Aug 2010
    Dallas, TX
    4,052
    Keep it there, I bet you have blue-gray water soon! (that's good by the way!)
    It will take longer, and take more chlorine, with the leaves in the pool though.
    Mar 2011
    North Carolina
    34
    How much longer you think, when the blue grey gets here what should I do then
    Aug 2010
    Dallas, TX
    4,052
    Keep the FC up until you can pass the overnight test. I can tell you though that if you have leaves in there, it's going to be almost impossible to pass the test. You need to get them out as soon as possible. You'll have to stay at shock level until you have everything out and can pass the test. The gray color will start going clear as your filter catches up, just keep the FC level up!
    Mar 2011
    North Carolina
    34
    Kinda weird as my filter has stayed right around 10 the whole time of doing all this, is that norml
    Aug 2010
    Dallas, TX
    4,052
    Yep but once it starts clearing it may creep up.
    That said, it will help if you can edit your signature line with all your major specifics like mine. I can tell you it will take longer to clear if you have a sand filter, for example. Mine takes a few days to clear from gray to clear.
    Mar 2011
    North Carolina
    34
    bumped back up to 15 ppm, still green, still depressed
    Aug 2010
    Dallas, TX
    4,052
    The leaves are going to make the process slow. Patience is key. It took almost a week to clear my pool the first time I had to shock, and it was just some algae on the floor and sides, not a swamp at all (no green water).
    Mar 2011
    North Carolina
    34
    Vacuumed some leaves out hopefully got most of them, ppm was 14 I bumped up to 20 for overnite. Hopefully the process will continue. However work tomorrow 12 hr shift 7a to 7p
