Thread: Plumbing questions?
    Plumbing questions?
    My pool gunite is complete, and am awaiting coping and tile work this week. I am acting as my own contractor and am getting limited help from the person that I am purchasing equipment from.
    The roughed-in plumbing consists of the following:
    1. Two main drains plumbed to single 2" line.
    2. Two skimmers each with 2" line stubbed out.
    3. Four 1-1/2" returns that are tied together in a single 2" loop around the pool.
    My questions are:
    A. Should the skimmers have separate 2" pipe runs back to the pump, with a valve for each, or tied together right before a single valve?
    B. The main drain line run 2" back to the pump?
    C. Is a single looped 2" return line adequate? I read that some pools use separate lines for each return?
    28,000 Gallon in ground Pebble Tec Tahoe Blue free form, Jandy 1.5 SHPM, Jandy 60 DEV, Jandy AquaPure 1400, Polaris 280, No Spa or water features.
    Re: Plumbing questions?
    Ideally the skimmers should each have their own 2" run back to the pump. I find it most useful to put a separate valve on each skimmer like and then a three way valve that selects between the main drain and the skimmers.
    Yes, the main drain should have 2" back to the pump.
    A 2" looped return system is alright, though it is nicer in some ways to plumb four 1 1/2" lines each with a valve.
