Results 1 to 8 of 8
Thread: How do I remove thick white line at tile
    aridpaul's Avatar
    Oct 2007
    Phoenix, AZ
    14
    How do I remove a 1 inch wide white tile line. I have already tried the pool pumice stones. That just seem to make it worse. The pool is 3 years old with a pebble fina finish.
    Thanks
    Loraine
    18,000 in-ground pool, Pebble Fina Finish, 2hp Pentair pump, Hayward 311sx sand filter. KT 2006 Test kit Tabs/bleach
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Have you tried the Mr. Clean white magic eraser sponge? I'm not sure that's its correct official name.
    Anna
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    aridpaul's Avatar
    Oct 2007
    Phoenix, AZ
    14
    Magic eraser
    Thanks for your response! Sorry I forgot to mention I tried that first.
    Loraine
    30,402
    Paul,
    Welcome to the forum. How did the stain get there? Without a pic, it sounds like calcium deposits.....muriatic acid is the cure.
    If we knew more about how it got there, what you think it is, or a picture, we'd be better able to help.
    aridpaul's Avatar
    Oct 2007
    Phoenix, AZ
    14
    It is definitely mineral deposits. It was fine the first 2 years of pool ownership. This year we had only one rainstorm in the summer. FYI I am in Phoenix. We had over 32 days of 110 degree weather. I don't know if that makes a difference or not.
    Paul and Loraine
    30,402
    Muriatic acid will remove it.
    More importantly, it sounds like your water has experienced high pH for a time to allow that much precipitate. Do you have a set of test numbers you can post?.....particularly pH and Calcium Hardness?
    What is the best way to apply muratic acid?
    built 4/08/2000 16 x32 460 Sq FT Pool 16,000 gallons 3.5 ft 5 ft 3.5 ft sport pool
    Jun 2007
    North Florida
    79
    Don't know if it's the best way, but when I clean mineral deposits, I use a quart-size trigger sprayer bottle. I use a 4 parts water, 1 part muriatic acid mixture. Some people start with more water (less dilute mixture). I make up about a cup of the mixture because that's usually more than enough for the few areas I need to treat. Always add acid to the water in the sprayer, not the reverse. I don rubber gloves and eye protection and hop in the pool. (What a sight, I know!! )
    You can wait until you're in the pool to add the acid to the water in the sprayer...that way there's not really any concern if you spill a bit...it just lands in the pool.
    Then, I spray a small area, let it bubble on the surface, scrub with a hand brush. Repeat as necessary. Rinse the area with pool water when you're done. When everything's done, I empty any leftover mixture into the pool and use pool water to rinse out my brush and sprayer, including the trigger mechanism. Then I take a nice relaxing swim as my reward
    Sandy
    15,600 gallon, screened 15 x 30 sport pool with 6 x 8 baja shelf, IG plaster (Diamondbrite??), Hayward cartridge filter, 1-HP Hayward pump, Hayward/EUS Mark VI heat pump, Polaris 280, AquaRite SWCG
