Results 1 to 14 of 14
Thread: Should I replace 3 year old pump to save $$$
    Jun 2010
    Alabama
    17
    I have a 16x32 inground vinyl pool that was built 3 years ago. It is about 17,000 gallons. When we had it built it seemed like a neat idea to have some of the Jandy Deckjets installed as well. Due to this the builder put in one large pump instead of 2 smaller ones. The pump is a Pentair WF-26 which is a 1.5 hp uprated pump, but it is single speed. The piping is 1-1/2 inch with a 400 lb sand filter. The pump is about 40 feet from the pool about 2 feet above it. My rough and dirty calculations come to .25 - .30 cents per hour to run this pump. So running it for 8 hours per day cost me around $2.00 per day. It gets run more on the weekends, so I figure it costs me about $80-100 per month to run the pump. This passes the smell test for my before-and-after-pool comparisions of my power bills.
    We never use the deckjets because you can't hear the music over them and it is hard to hear someone next to you if you are having a conversation. Only during a party will we turn them on - couple times per year.
    Anyway, I was thinking that it may be worthwhile to scrap the 1.5 hp pump and go with (A) a smaller single speed pump, (B) the same size 2 speed pump, or (C) the multi speed Intelliflow pump. If I could save 50% on the power consumption it would pay for itself quickly.
    One other note, I do not close my pool in the winter and am running the pool with a Goldline system with freeze-protect turned on at 35 degrees, so the pump does run a lot in the winter, even her in sunny AL. Also the deck jets are setup to turn on during freezing weather as well so they need flow as well.
    If I could cut the power consumption in half it would almost pay for the Intelliflow pump - am I missing something? Also with the multi-speed pump I would have plenty of flow in the event that I need it for the deckjets.....
    thanks,
    22,553
    Re: Should I replace 3 year old pump to save $$$
    In Alabama it's going to be hard to justify the variable speed pump but if you go with a 2-speed of the same SFHP you'll save a good bit of money. That'll also allow you to run the deck jets if you ever decide you want to. The breakpoint for VS payback is about 24 to 26¢ per kwh.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Dallas TX
    186
    I'd suggest replace the motor with 2spd, not the whole pump. A new motor will bolt right on, maybe $300 or so, and get a lot of the benefots of the vfd without the high initial cost. Looking to do this myself for many of the same reasons
    33k Gunite, CompuPool CPSC48 SWG, Sta-Rite System 3 DE, 2.25hp dual-speed, POOLVERGNUEGEN Pressure-side
    Jun 2010
    Alabama
    17
    Quote Originally Posted by acroy
    Had not thought about that. That may be the way to go. With a 2 speed pump do you control the different speeds on the pump or can I set it up through my Goldline system?
    Either way. Most people leave the pump on low and only manually turn it up to high when priming the pump or vacuuming. But it would be very easy to setup the automation system to be able to control both speeds instead.
    Jun 2010
    Alabama
    17
    If I purchase the WF-26DS motor, which is the same motor but 2 speed, will the low speed have enough flow for my SWCG? I found the pump motor online for $270 - Not too bad.
    It definitely should. The actual flow rate depends on details of your plumbing, but from the specs I see above you should be just fine.
    Jun 2010
    Alabama
    17
    I remember now when setting up the Goldline that there is a setting for single vs 2 speed pumps so I would need to change that in the Setup section. Is there any difference in wiring? How does the Goldline controller change it from low to high?
    Thanks. Great site, BTW.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Assuming you have an AquaLogic controller like mine, low speed uses a second relay and you configure the relay as low speed so the controller is two speed aware. With the Aqualogic, the pump will always come on at high speed for 3 minutes for priming before switching to low speed if that is the desired cycle. You can separately control the high speed and low speed schedules. I have mine setup for a couple of hours on high for the cleaner before stepping down to low speed. Also, if you have solar, high speed will engage when solar is engaged and then automatically switch to low when solar is not needed which is a nice feature to have with solar. Other than that, it is fairly easy to setup and use.
    Mark
    Jun 2010
    Alabama
    17
    So, the motor must have some low speed wiring and some high speed wiring?? One relay goes to each?
    I can handle the relay and configuring the controller. Just curious about the motor.
    Yes, the pump has separate high and low speed terminals. It will also have a common terminal used at both speeds for the second hot wire (or the neutral wire if it is 115 volts). It is very easy to wire, there should be a diagram in the controller manual, and a diagram on the motor telling you which terminal is which.
    Aug 2008
    Dallas (Plano), TX
    41
    Quote Originally Posted by mas985
    ... I have mine setup for a couple of hours on high for the cleaner before stepping down to low speed.
    Why do you run your filter pump on high when your cleaner is running? Does you cleaner not work properly if your filter pump is on low? Is your cleaner a pressure side unit or something else?
    Many thanks!
    Best regards,
    Bill
    30 KGal IG plaster pool with diving board & spa, built '96; 2 speed (2.2/0.28 THP) AO Smith B2983 hi efficiency motor for circ (3 skimmers w/ 1.5" lines & drain w/ 2" line) (replaced original 1 speed Sta-Rite Max-E-Glas II 2.0 THP pump in 2011); waterfall w/ Sta-Rite Max-Glass II 2.5 THP pump w/ 2.5" lines, Polaris 280 pressure-side cleaner w/ 3/4 HP pump, Sta-Rite System 3 Vertical Grid 53 sqft DE filter, AquaLink RS6 P&S w/ 52 pin Rev K.33 controller, Rainbow offline tri-chlor erosion feeder, 450 KBTU/hr Rheme gas-fired heater, Dallas climate, 10/kwh current electric rate, energy monitoring system at http://www.welserver.com/WEL0043
    mas985's Avatar
    Pleasanton, CA
    11,742
    I run on high speed for several reasons:
    1) Solar requires high flow rate and pressure due to the height of the panels and the placement of the vacuum release valve.
    2) Skimming works much better on high speed than low speed.
    3) I want both skimming and the cleaner running at the same time and there just is not enough flow rate on low speed for both.
    Mark
    Aug 2008
    Dallas (Plano), TX
    41
    Mark, thank you.
    I've learned what 'works' on Lo speed. I'm still learning what 'works well' on Lo speed.
    Best regards,
    Bill
