Results 1 to 8 of 8
Thread: Opening Numbers from Sevver
    Mar 2007
    Morris, IL
    477
    My pool has been open for a few weeks, but I have not done a full blown test on it til now. I wanted to wait for my new tfp test kit.
    FC = 1
    CC = 0
    TC = 1 verified with the daily test kit too!!
    TA = 230 I fought that all last year too.
    CH = 210
    CYA = 30
    Ph = 7.8
    From this, I can see that I need to add more chlorine, and that my Ph is getting high. The Ph thing is probably due to the TA being so high. I think I am going to try to connect my air compressor to my Tee I have in the return line... I really had a hard time last year trying to lower that, and I think it is where I left off last year, it was originally around 280.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Mar 2007
    Morris, IL
    477
    Now it is time for me to try to speed up the lowering of my TA. I am introducing my air compressor into the jet return, thus making lots of bubbles. I will continue adding muriatic acid, keeping the Ph at around 7.2 or so while aerating the water. I would love to get it down and hopefully it works. Here is some pics.
    If anything, I got a hot tub out of it.
    steve
    Arizona
    924
    That's using your noggin'. Pretty cool jury rig to solve a problem.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Quote Originally Posted by sevver
    ........If anything, I got a hot tub out of it.
    I was thinking Giant Jacuzzi!!
    We can now call you Clever sevver!! 8)
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Mar 2007
    Morris, IL
    477
    Thanks, I started this today with a TA of around 210, I am going to leave it going til after I get out of church tomorrow at 12:30 or so and retest it. I am going to go out and check the Ph again now.
    steve
    Mar 2007
    Morris, IL
    477
    Woke up this morning, and checked numbers.
    Cl was 2,
    Ph was 7.8,
    I lowered the Ph to 7.2 and raised the Cl to 4
    Then I checked the TA and it is already down to 110. I plan on letting it run until about noon today and testing it again. This is working like a charm.
    steve
    East Tennessee
    278
    Server
    Great ideal ... but have a question?
    How much pressure is the air adding back in to the system ?
    The reason I am asking is I am working on a ideal to build a system / gadget that will drop ALK in a faster with out the need to drop the pH in the whole pool.
    Steve
    Echo Canyon II by Artesian Pools, 13.5 KGal AG Round, 22" Artesian Sand Filter 2 hp Artesian pump
    Med Lab Tech for 12 years in E.TN
    Chem testing by Trouble Free Test Kits
    Mar 2007
    Morris, IL
    477
    My gauge is questionable so I am not sure. I will get a new gauge and check it with the air off, then with the air on. The thing is, the air comes in way after the filter, right before the return, so I would think that the pressure just gets expelled out of the easiest place, which would be the jet. If I point the jet out of the water, you can definately both hear and see a major difference in pressure. And if you look at the return fitting outside the pool, it is actually shaking.
    steve
