Thread: New handrails for existing pebble-tech pool
    Oct 2007
    Queen Creek, AZ
    27
    I am considering making an offer on a house which already has a small pebble-tech pool. There are no handrails at the steps. I am handicapped and would need to have two rails installed, so I could support myself on both sides while entering/exiting the pool. How difficult and costly a task would this be to do in an existing pool?
    (My apologies if I posted on the wrong forum. I couldn't decide if I should post here or in the equipment section.)
    Thanks in advance for any input.
    Built 3/08: 12x30 IG gunite/plaster play pool w/ in floor cleaning heads & auto water leveler, (10,584 gal), two Jandy Stealth SHPF 1.0 hp pumps, Jandy CL460 cartridge filter, Taylor K-2005 test kit.
    Hi, and welcome to TFP!
    This looks like a fine place for your post. Unfortunately, I cannot answer your question!!
    Someone who can will be along shortly!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    You can get rails which are mounted only to the deck, so the pebble-tec won't make any difference.
    If you have to mount something to the pebble-tec it can be done fairly easily if you don't mind the risk of having a little bit of obvious patching around the mounting point.
    Oct 2007
    Queen Creek, AZ
    27
    Thank you for the welcome and the replies.
    I do not think deck mounted rails would go far enough down the steps or support enough weight, but if they could be mounted into the pool that would be great.
