Thread: Hayward Heater AO error
    Hi,
    I am getting an AO error on a friends Hayward Gas heater.
    The heater blower vacuum switch (rss-495-061) seems to work when I suck very lightly on it (when I do this the error instantly goes away) There is not any noticibly suction coming from the fitting on the blower (fan). The fitting is clear since I can easily blow and suck with my mouth, but yet when the blow fan is on I don't notice any suction.
    The fan motor spin so i feel the motor is good. In my experience if a motor is running slow it will burn out. The squirrel cage spins very easily when off. The motor is quit when running.
    This tells me its either the vacuum switch or the motor.
    TIA
    16,000 Plaster/Gunite - Pentair FNS Plus Fiberglass D.E. Filter
    Heat Siphon Heat Pump Z375HP- Hayward Pro Logic PL-P4 Automation
    Hayward Chlorinator Cell T-CELL-9 - Waterway SVL5 Pump
    A.O. Smith Two Speed Motor B983 - Solar Blanket - Polaris 380
    Test Kit K-2006c
    22,550
    Re: Hayward Heater AO error
    Have you checked the air path? It sounds like there's a restriction in the outlet channel. That will cause a reduction in flow and therefore a reduction in suction pressure to the air flow switch.
    I pulled the motor from the housing and had no suction at the hose fitting mounted on the motor. I could blow air with my mouth in the fitting and there was "0" restriction.
    Someone told me this motor should really spin and make a decent amount of noise, a desk fan has much more air flow than this squirrel cage motor.
    Test Kit K-2006c
    How did you end up resolving this issue, I have the same exact problem and need it fixed soon.
    In advance, thank you for your help with this matter.
    Intex 18' x 52" Ultra-frame AGP, 8200 gal(?), used
    Intex 2650 Sand filter/pump, new (happy dance!)
    Intex SWG 8110, used
    Intex Wall Mount Surface Skimmer/Vacuum, used
    Solar Cover, used and a Patch Kit, now used.
    It turned out to be the Motor. This was for a friend and they called a pool company and they determined right away that it was a bad motor. I didn't want to take the chance since the measly motor was around $200 or more and didn't want to steer a friend wrong.
    Suck on the vacuum switch switch to see if the error goes away. I replaced the switch since that was only like $25 dollars but that didn't help.
    Good luck and let us know how you make out.
    Test Kit K-2006c
