Thread: Badly stained - yellow/green looking
    I have a vinyl liner pool that is badly stained, yellow/green looking. The odd thing I see reading about stains is, wherever I had leaves or other debris on the pool bottom, the liner is perfectly clear, but everything else, including the sides is stained. A similar problem a couple of years ago cleared up by using the 3-in-one chlorine tablets. No such luck so far with that. Any suggestions as to where to start? My pool is approximately 25,000 gallons.
    Thanks - Ed
    BBB/TFP Evangelist!
    6/13 - Pulled the trigger on a Heritage 21'x54". Under construction
    5/12 - Upgraded to Confer Plastics Heavy Duty A-Frame Pool Ladder and 8-mil round solar (bubble) cover.
    5/11 - Our first pool! 6000-gallon Intex Ultra 16'x48" AG with standard 1500 gph 1/3hp cartridge filter.
    Re: Badly stained - yellow/green looking
    Try holding a Vitamin C tablet against one of the stains for 30 seconds and see if the stain lightens or clears up in that spot.
    The vitamin C worked! I gently rubbed a tablet on the stain and it was completely gone. Thank you. Now, can you tell me how I apply that to the entire pool?
    BBB/TFP Evangelist!
    You need to do an AA treatment. There are directions and discussion in this topic.
    Can you tell me if Suncoast Stop stains is simply ascorbic acid or is it something more powerful? I have what Pinch-A-Penny calls sugar scale. They suggest 25 pounds of Suncoast Stop stains at about $7 a pound to get rid of it. Seems pricey but if that is all I can do then so be it.
    Thanks - Ed
    BBB/TFP Evangelist!
