Results 1 to 8 of 8
Thread: Chlorine and pH test kit....TF-100
    Jan 2011
    Northern Illinois
    116
    Does anyone else have a problem reading the results on the daily chlorine/pH test kit included in the Tf-100 kit? Maybe I'm partially colorblind, but I have a very difficult time differentiating between the shades of yellow and red.
    Wil-Bar 27'x54" Quest AGP
    Hayward 1HP Powerflo Pump
    Hayward 256 T Swimpro Sand Filter
    Re: Chlorine and pH test kit....TF-100
    It is common to have some trouble with the PH kit. Using a sunlit white background helps as does practice.
    Jan 2011
    Northern Illinois
    116
    Thanks. Are there any other relaible tests (such as strips etc) that can be substitued for the daily test? I feel like I'm going blind trying to read the one I have now!
    30,431
    With a little practice (and remember you don't have to be "perfect"), the OTO test is almost ALWAYS more reliable than the strips Stick with it for a while.
    When I first started, the OTO chlorine test was much harder for me then the pH. What I started doing was eliminating the shades that were too yellow or not yellow enough. In other words, I eliminated the extremes......the shades I knew it was not. That left me usually only with a couple of choices left which is normally good enough. Now, I can get it right virtually every time.
    There are many other OTO comparator blocks available but Taylor's has seemed to always get the best results by most folks here on the forum. I simply could not trust test strips.
    I don't even use the Chlorine test with that thing. I always do the drop test (using the powder) - I can't read it the colors, like you, and it's such a small range on the reading block that it's essentially useless. I only use that little device for the PH test.
    21x41x54" AG Artesian Seville II
    Installed around 2004 - we moved here in 2008
    23,000 gal
    Hayward SwimPro 256T Sand Filter
    1HP 2speed Hayward Power Flo Matrix
    (and have 2HP Hayward Swimpro and a 2hp 2speed Waterway Hi-Flo pump as back up also!! lol)
    No heating - other than Solar SunRings
    Central IL
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Yes. The chlorine test is especially useless to me.
    For the pH test, I have fopund that holding the test block at arm's length with something white in the distant background (in my case, usually a white plastic patio chair) then squinting so the numbers are unreadable makes the color differences noticeable. I can usually even tell if it's closer to 7.5 or 7.2 that way. Try it.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by pmsmith2032
    If you think about the pH test as trying to match the "yellow-ness" or "magenta-ness" it seems to help. You aren't trying to match the shade or tint, just the hue.
    Mar 2007
    San Rafael, CA USA
    12,082
    You can also slightly vary the number of drops you add, so long as your FC level isn't too high where you might need all 5 drops to neutralize the chlorine. I find that in my K-2006 pH test the color matches better with 3 or 4 drops than with 5 (if you need more saturation instead, then 6 or 7 drops will do that), though as was stated above it's the hue that is to match, not the saturation or lightness.
