Results 1 to 8 of 8
Thread: What to do with old chlorine tablets?
    Jan 2011
    Northern Illinois
    116
    We had a 27" agp pool installed this past weekend and want to go the BBB route. However, we have a bunch of 1" and 3" chlorine tablets leftover from last year's intex pool. Are they of any use anymore or should we get rid of them? If they aren't of use in our new pool, how/where do we dispose of them? After adding a gallon of bleach last night, the FC level was at 5 and we have CYA of 0. Thanks in advance!
    Wil-Bar 27'x54" Quest AGP
    Hayward 1HP Powerflo Pump
    Hayward 256 T Swimpro Sand Filter
    Sep 2009
    Frederick County, MD
    184
    Re: What to do with old chlorine tablets?
    Use them to raise your CYA, then STOP!
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
    Since CYA is at zero right now, you could use up your trichlor tablets on the pool. They will raise FC, raise CYA, and lower PH. So keep an eye out on the PH. That will be easier than trying to find a safe way to dispose of them.
    Jan 2011
    Northern Illinois
    116
    Do I add them just using one of the dispensers that float around? Can I use these tablets for the next week until I test the water again for CYA next weekend?
    Yes, and yes. A floating tablet feeder is a good way to go.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Keeping a few on hand can be a good thing for vaction use, etc.
    Ike
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    Give them to someone you don't like to much.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    Keep enough to get the pool through your next vacation. It is hard enough to ask someone to come take care of the house when you are gone. Water the plants, get the mail, empty the skimmers, check the water level on the pool. If you can get the chlorine taken care of for the most part by using the floater or automatic, then they won't have to do too much testing or dumping of bleach for you. A week of using tablets ought to not make that much difference to the CYA level if it is a bit on the low side when you start.
