Results 1 to 7 of 7
Thread: Jacuzzi laser Sand filer 225L
    I have an in-ground 16x32 pool. We installed it 10 years ago. I just removed the original sand and replaced it. Now there is one bolt that will not go all the way in where the dial valve connects to the tank. I can see that there is not a perfect connection and it is leaking when I run it. I have been careful to not over tighten. I did use petroleum jelly on the o-ring and the hex bolts. I also tried to clean out all sand in the bolt holes and on all parts.
    Can anybody give some things to try?
    Jack
    Jack
    Massachusetts
    16 x 32 (18,000 Gallons) in-ground pool
    vinyl liner
    Jacuzzi Laser Sand 225L filter (2002)
    22,553
    Re: Jacuzzi laser Sand filer 225L
    Take a picture of it and post it here. Someone will know what to try.
    I took a couple pictures and posted them at photobucket.
    http://s1087.photobucket.com/albums/j478/jj1918/
    Hope this helps.
    Jack
    Jack
    Massachusetts
    vinyl liner
    22,553
    That helped a lot. Back that bolt out and take a straw (or other small tube) that will fit into the hole and blow the trash out of it. An air compressor would work best but you might be able to do it with oyur breath. I bet there's either sand or debris in there. You might need to take something small (i.e. a screwdriver) and help dislodge it too.
    Protect your eyes!!!
    Thanks. I used a compressor and got a nice tight seal. Just in time for the first 80 degree day in my area since last summer.
    Jack
    Jack
    Massachusetts
    vinyl liner
    22,553
    Glad it worked out for you. Now go enjoy that pool!
    With a bit of luck, we will be swimming this weekend.
    Thanks again.
    Jack
    Massachusetts
    vinyl liner
