Thread: Polaris 9300-IntelliTouch
    Apr 2010
    North Alabama
    25
    I've been looking for an electric pool cleaner that could be integrated with Pentair's IntelliTouch system. I like the Polaris 9300, but it comes with the large stand that is plugged into 110VAC.
    My ideal pool cleaner would be an electric version that could stay in the pool most of its life and is only removed during swimming times. I would like to use IntelliTouch to turn on and off the cleaner automatically using preset programs or manually using the touchscreen display.
    I know I could do this if I used a non electric version and had IntelliTouch turn on a boost pump at certain times. The only problem is I want electric. What would be a good angle of attack?
    The pool is currently under construction so as of now, the possibilities are limitless.
    24,480gal True L. 1.0HP pump. Sta-Rite Cristal-flo T240BP1 with a WC112-147/148 multiport.
    Oct 2010
    Eastern TN
    172
    Re: Polaris 9300-IntelliTouch
    Dolphin makes models that allow them to be programmed to run by schedule. No external control needed.
    9300ix can be plugged into a timer and will run as scheduled.
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
