Thread: confused...
    May 2011
    Hardy, Virginia
    61
    confused...
    Ok guys...so I shocked my brand new pool for the first time last night. This morning I tested it and the free chlorine is through the roof at 10. All the other tests came back at the lowest possible reading. I'm very new to this and don't know if this is normal or not. How long will the FC stay up like that? I wasn't able to run the filter all night because of a thunder storm/tornado watch. I did turn it on this morning. Could that be it? And what do I do next with the chemicals?
    15' wide x30' long x 4.5' deep vinyl above ground, 13,500 gallons, hayward dream line sand filter, hayward power-flo lx pump 1.0 hp, lil shark cleaner
    Butterfly's Avatar
    South Carolina
    10,045
    Re: confused...
    Your pump should be running at least an hour before you test.
    I suggest you retest and post back with all your numbers.
    You're done SLAMing when:
    22,544
    Re: confused...
    Please explain 'how' you shocked it? Also explain how you tested the water and post a full set of test results?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: confused...
    Kirsten, Welcome to TFP
    As mentioned above, posting a full set of test results will help. Also do please note how you are testing the water and why you decided to go through the shock process. Test strips and pool store results are known to vary quite a bit, with a good at home drop based kit being most consistent and dependable.
    FC of 10 is not all that bad if you have enough CYA in your water....the issue with your post is that we have no idea what "All the other tests came back at the lowest possible reading." means
    You can read more about test kits here
    pool-school/pool_test_kit_comparison
    Now let's see if we can get your pool season started
