Results 1 to 10 of 10
Thread: To Be or not to Be
    Apr 2011
    South Point, Ohio
    32
    To Be or not to Be
    My pool has been open since April and we had a pool party this weekend (8 Kids, 3 Adults) this was the first time anyone had swam in the pool this year as the water temp is still 66. When we took the solar cover off before the party we seen on the bottom of the pool in a couple of spots had what looked to be a fine brown dirt. Once everyone started swimming i noticed the spots seemed to vanish as they were probably mixed into the water. The next morning i walked out to the pool and they were back again! So i preceded to sweep the entire pool, backwashing very often. After i was finished the pool floor looked beautiful again. So as i felt like mission accomplished my wife and i leave and go out to eat. Upon our return, Hour and a half i look into the pool and those spots are back again!!!!
    After reading on here i was starting to think it was mustard algae, but after reading further on the board and seeing that mustard algae does not like sun, and my spots are happening more towards the middle of the pool where sun always beats down for 3/4 of the day i am starting to think it is not. I am now leaning more towards it being pollen as i can not imagen algae growing back in this short amount of time, and pollen levels are always way high in our area. On another note my water is sparking blue and clear more so now that i am using an LQ.
    Here are my levels as of this morning:
    FC : 5
    CC:0.5
    PH:7.5
    TA:90
    CYA:35
    I was thinking of adding a skimmer sock while brushing the bottom to see if that may help these blasted spots!! Any input or suggestions would be greatly appreciated.
    24' Round Above Ground
    15,000 Gallons
    Hayward Pro Series 100 Lbs Sand Filter
    Hayward Power Flo LX 1hp Pump
    8 gallon Liquidator 3/8
    BBB Method
    22,550
    Re: To Be or not to Be
    I hope that CC is supposed to be .5 and ont 50.
    Using a skimmer sock should help but even they won't always get all the very fine pollen, at least not on the first pass.
    Apr 2011
    South Point, Ohio
    32
    Oppps. you were right .5
    With the spots coming back that quick do you think that it is impossible for it to be a type of algae?
    15,000 Gallons
    BBB Method
    That sounds exactly like fine silt settling out of suspension after you mixed it back into suspension by having lots of people swimming. You need to vacuum it up slowly and carefully so you don't just mix it back into suspension again.
    22,550
    While I'd never say impossible, given the FC & CYA level, it's highly improbable that it's algae. I bet it's dust and pollen. I fight the same thing and I know it's not algea in mine.
    If you really want some peace of mind, run the OCLT. While I don't think you need to, it'll settle your mind about it.
    Apr 2011
    South Point, Ohio
    32
    Well i returned from getting my skimmer socks at the local pool store and just for the kicks i took a water sample with me to get them to test it while i was there (all levels tested good). I proceeded to explain to them why i needed the skimmer sox, and the PS employee stated that i in fact had a serious algae growth going on and proceeded to tell me that i need to purchase a bottle of algaecide, a case of liquid shock, a bottle of clarifier, and a tub of chlorine tablets with strict instructions to stop using the liquidator and bleach as this is method can not be effective as they have never heard of anyone using this so called liquidator. In the end i told him " You seen my water test, and they do not lie so i will keep doing it my way", that was returned with the smart *** statement from him of "well when you pool turns completely green don't calls us."
    PS Its been 4 hours since my last sweep and the spots on the floor of the pool has not returned yet.
    TroubleFreePool.com = 1
    Local Pool Store = 0
    15,000 Gallons
    BBB Method
    22,550
    Apr 2011
    South Point, Ohio
    32
    Well after a good slow sweeping with the skimmer sock in the skimmer and one on the return coupled with another few hours of running the pump with the socks in place the pollen has not reappeared on the floor of the pool. But i did have to rinse the socks out about every 25 min. during normal circulation, and about every 10min. while i was sweeping. Below are my final results.
    Again a big thanks to everyone for your help!
    15,000 Gallons
    BBB Method
    Apr 2009
    Burlington, ON, Canada
    344
    Quote Originally Posted by mrnick0483
    Regarding the pool store: How about just 'don't call us'.....ever...for anything....
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    The funny thing is, people who do follow his instructions have their pools turn green, and then they come here!
