Results 1 to 13 of 13
Thread: Thumping with pump off
    When my filter pump shuts off for the night I sometimes get a loud thumpimg noise from the pipes. If I open the filter bleeder valve I can get it to stop but was wondering if anyone knows what causes it and how to stop it. I have a 1.5hp superpump, a 90 ft^2 cartiridge filter and a heatpump, plus a 2.5hp superpump for the spa.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Thumping with pump off
    Air in the system is causing the thumps. Likely you have a suction side leak.
    Love TFP? Become a
    TFP Supporter!
    22,553
    Do you have any air in the pump basket when the system is running? (following Zea's lead)
    no there is no air in the pump basket when the pump is running. It starts when I turn off the pump and stops when I let air into the filter canister.
    22,553
    When the pump is running, and you open the air bleed, does any air come out?
    no it sucks air in.
    22,553
    There's something seriously wrong there. Lets get this straight. I'm talking about the air bleed on the filter with the pump running. Is that the bleed you're opening?
    Mar 2011
    441
    Is the heater running when this happens?
    20X40 30,000 gallon gunite pool
    yes that is the air bleed, no the heater is not running. Everything is off when the bangin occurs, overnight it gets softer and softer till it stops. It does not happen all the time only sometimes. I beleive after checking online it is called a water hammer but I don't know how to stop it.
    22,553
    I've got to see a picture of your equipment setup.
    When you open the air bleed with the pump running it should shoot out water or air. Absolutely nothing should be able to suck in. The filter should be on the pressure side of the system.
    It does pump out water with the pump running, all works fine, good flow, no bubbles, pressure is correct but when the pump turns off I get a banging sound that goes on for hours. If I releive pressure by opening the relief valve allowing air to enter the system the banging stops, if I turn on the pump the banging stops. Also when I had a leak in the return line the banging was not present.
    22,553
    Ok I thought it was sucking in air with the pump running.
    It sounds like there's a small vacuum leak in the filter or plumbing, causing air to back into the filter causing the water to gurgle out and creating the thumping you're hearing. I think if you find and fix that leak you'll stop your thumping.
    Thanks will check it out.
