Thread: Deck-O-Seal
    Palm Springs area, CA
    70
    Deck-O-Seal
    Ok, I bought a tube of $$ deck-o-seal one step to seal the joint between my cantilever pool deck and the stone tile lining the water line.
    The sealant was extremely, and I mean extremely thick. I literally deformed my caulking gun trying to get it out of the tube - bent the metal ends. It was almost like it had started to cure in the tube. I don't think this can be normal. I tried to smear it into the gap and it was so thick it would not change shape to fit into the gap.
    Is this normal for deck o seal? Did I get a bad batch?
    11,000 gallon in-ground pool/spa combo, pebble-tec, Sta-rite system 3 cartridge 300 sqft, Pentair Whisperflo WFDS-6 2 speed 1.5 HP full-rated, formerly Starite Max-e-Glas 2 HP up-rated single speed, Sta-Rite Max-E Therm natural gas heater. Jandy Aqualink RS Onetouch. Manual vacuum. Chlorine.
    Re: Deck-O-Seal
    Probably a bad batch. Caulk will go bad in the tube if it is old, the tube has been damaged or if it has been kept in an improper storage conditions.
    Support the site
