Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: 2 x fafco solar bear panels parallel connection problem
    Hi there, I have followed "experts" advice, to connect my 2 panels in parallel, instead of serie connection... well, on the water out from filter, to panels, I installed a "Y" to bring water to lower panel, and of course the top outlet of my "Y" go to top panel, but the problem is, water does'n t get to the top panel !!! any clue on why this is happening ??
    My initial idea was to simply connect the pannels in serie, but I've been told paralel was better. So where I made a mistake ?? I know if I make connection in series, I can't see any reason why it wouln't work. anyone know what's wrong ?? Perhaps I should have inatall the " Y" splitter on top panel instead ???
    thanks,
    12' above ground pool install "inground" - hayward pro-lx serie sp-2295 pump - hayward vari-flo sp704 - 2 x 4' x 20' fafco solar bear panel
    for polar bear living north pole, Quebec city , Canada
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: 2 x fafco solar bear panels parallel connection problem
    If by "Upper Panel", you mean one of the panels is higher above the ground, your lower panel may not produce enough pressure to raise the water to the upper panel at the flow rate of your pump. All of your water could be going through the lower panel too easily. Maybe a valve on the inlet to the lower panel?
    The total length of the path going through the panels needs to be the same regardless of which panel the water goes through. Usually this is done by running water into both panels from the bottom, and then taking the return from both panels up to the top of the top panel and then down from there. Keeping the paths the same length and the same maximum height will balance the flow rates of the two panels.
    Sound's logical... I will try to draw a plan and show you guys for "approval". So if no body suggest to make a serie connection, it means every one seems to agree on parallel connection is best !
    thanks again for your help
    Parallel is much better.
    Do you think your suggested connection is possible if my panels are install one next to each other (one on bottom and the other on top) not sure to fully understand. I read on an old TFP topic, a guy were talking about both tipe on panel disposal, but as for my installation, I just can't place them "in line". I tried to search for installation diagram but can't find any.
    thanks again
    My drawing isn't very good, and it does depend on how your panels are laid out, still here is a picture of what I am talking about:
    [attachment=0:2m7wnv83]solar.gif[/attachment:2m7wnv83]
    I have include 2 different drawings, 1st is my current connection, which don't work. and a 2nd which represent what I've understand from your explanation. Please take note, on your drawing, I think it just can't be applicable to mine, since fafco panels have inlets and outlets on same header side. Please tell me if my "idea" would work.
    thanks again for your help.
    In both of your drawings, the water travels further and goes higher to reach the upper panel. In my drawing the water travels the same total distance and goes to the same peak height through either panel.
    You need to do something much more like my drawing for the water flow to be balanced. Your panels are configured differently than I was assuming, but you can simply flip the plumbing I drew on the right over to the left hand side and it will work with your setup.
    SW Indiana
    9,199
    The key thing is that all of the water entering both panels needs to go to the highest point before going to the panels.
    22,553
    There have also been people that have bored out the divider in the header so that the panels could be plumbed like Jason's drawing.
    All right, now please take a look at the updated "parallel connection idea" and tell me if this time I get it right !!
    thanks !
    Good, much better. I would run the water the other direction, so water travels up through the panels instead of down, but otherwise that is exactly what I recommend using. And the up/down thing isn't crucial.
    Like this one ????
    Yes, the water flow through the panels from this diagram, but the plumbing from the previous diagram.
    So, if I understand, what I need to do, is to interchange inlets & outlets on my panels ! Otherwise, I don't see how I can take the "water flow" (from my red arrows direction) and use plumbing from previous drawing, since in both drawings, the inlets & outlets are not on same side.
    I'll try to have another drawing for you.
    thanks !
    The direction of flow is a minor issue. However, all you need to do is turn the arrows around on the drawing I like and don't change anything else.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    You cannot lay them end to end? I have those same panels and other than laying end to end, my parallel plumbing is the same as your last diagram without having to remove headers or modify the panel construction. It works very well, all the piping and fixtures are in one area instead of apart.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Nop ! I don't want to install them end to end, cause I already made a "wood frame base", and I just don't want to styart all over again !
    So, I think I'll change it as per Jason's instructions.
    May take a couple of days... my wife is also on vacation this week, if you know what I mean !!!
    I'll keep you posted for sure.
    thanks to all
  20. Back To Top    #20
    Apr 2009
    Burlington, ON, Canada
    344
    I've gotta tell you, it's nice to see people asking for advice and good advice being given and followed. What did we do before the internet??
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
