Thread: I think I'm settling in...
    Well, I guess this is mostly a "Thank You" post for all the great info I've learned from this site. So far I'm feeling pretty fortunate with how well everything has turned out so far.
    For the past 7 or 8 days, the numbers each evening have been the same. Chlorine level showing at 2 or maybe a smidge more. Adding 48 oz of bleach each night has given me the same reading the following night of 2.
    Today I ran my 2nd full round of tests with the TFT-100 today and here's the results:
    FC-2.5
    CC-.5
    pH-7.5
    TA-60
    CH-320
    CYA-30
    Temp-75 F
    The CYA is down a bit, so I'll likely add some more this week (we've had a moderate amount of rain since I added a little a couple weeks ago). My TA is on the low side, but so far running it a bit on the low side seems to help keep my pH in check (before lowering it a bit my pH would regularly drift above 8).
    I guess I feel like I'm "there." Pool looks great. Numbers seem pretty good. Thanks to TPF I feel a lot more in control of what's happening and definitely more confident in the ability to handle any potential situations as they arise.
    -11,000 gallon IG gunite, raised spa overflowing to pool
    -Cleaning Pump: Sta-Rite P6E6E-206L
    (runs what I think is a Vantage system; alternating, rotating floor jets)
    -Filter Pump: Jandy FloPro FHPM1.5-2
    -System 3 S8M150 filter
    Re: I think I'm settling in...
    Feb 2008
    Denton, TX
    5,061
    Glad to see that things have clicked for you. Sure does make enjoying the pool a little easier doesn't it?
    Indeed it does....lol, my daughter still hasn't gotten used to it yet as everyday she still asks "Is the water safe?"
