Thread: Recommended FC level..
    Do I try to match that right in the morning, or do I try to match that level in the evening. Basically just trying to see which reading matters more..
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,599
    Re: Recommended FC level..
    If you bump your chlorine up at early evening............you've got more FC sittin' around at night usually when the pump isn't running. At least it works for me. Just gonna eat it during the day.
    The recommended level is a range. One goal is to never go lower than the low end of the range. The lowest FC normally gets is in the early evening, so that is a good time to check to make sure you are not going lower than the low end of the range. The high end of the range is more of a guideline, raise FC to around there in the morning (or the night before) and you should still be able the minimum by evening. But that needs adjusting based on your specific pool, sometimes a little higher sometimes a little lower.
    Hope that helps.
