Results 1 to 7 of 7
Thread: where does this bolt go?
    Jul 2009
    Massachusetts
    188
    I'm opening my pool for the second time and I used a different company last fall for closing the pool. This company removed more bolts/handles than the last one and I figured out where they all went with the exception of one. unfortunately, i don't have my camera handy, so I'm hoping someone can help me figure out where it goes without a picture for now. It's has a hexagon head and the head and the screw part are both approx. one centimeter in diameter. It's coated in black rubber. We have an inground gunite pool, with a booster pump, de filter, chlorinator, and heater. This bolt was stored in the pump basket with all the handles for turning on/off the returns, main drain, water fall, the bolts that help drain the pump basket area and the bolt that (i think) drains the tri-chlor chlorinator. We looked and couldn't find any other 'hole' that needed a screw. any ideas? i'll post a picture as soon as I can get my hands on my camera.
    thanks so much..
    25,000 gallon gunite pool with waterfall (built 2000 - owner as of 2009), Aerotemp / Aquacal heat pump AT12000-A, Hayward DE4800 Filter, AOS UST1202 Motor, Hydro-King T104P201 Timer, Meyco pool cover, Pentair Model 320 Auto Chlorine Feeder. Located in Massachusetts.
    Jul 2009
    Massachusetts
    188
    Re: where does this bolt go?
    Got the camera
    Feb 2008
    Denton, TX
    5,061
    Looks like a drain plug from a pump basket.
    That looks like the drain plug to the PB4 Booster Pump.
    Support the site
    Jul 2009
    Massachusetts
    188
    thanks a bunch! it was the PB4 pump.. now I just need to find a way to tighten it to stop it from leaking..
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Looks like somebody has used silicon RTV on it in the past. You might try teflon tape on the threads or pipe dope labelled for plastic use. I assume that isn't supposed to have an O-ring.
    Jul 2009
    Massachusetts
    188
    great..i will pick up some tape..
    thanks again for all the help!
    patty
