Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Calcium question
    Jul 2010
    Montreal, Canada
    49
    Calcium question
    Hi guys,
    Im opening the pool for the first time did the water test and was told i need to raise hardness, so ive added calcium, next step is to start my shoking process by adding degreaser
    Now my question is, how long do i need to wait after adding the calcium, to be able to add degreaser
    Thanks
    18 feet AGP
    SWG
    Catridge
    An hour NW of Philly
    76
    Re: Calcium question
    Step 1: don't add anything other than liquid chlorine and ph adjustments right now....
    Step 2: go read pool school
    Step 3: don't trust pool stores; get accurate numbers to post in here...pool school lists recommended test kits
    Step 4: do what the experts here recommend
    Step 5: enjoy your clean and clear pool all summer
    27k Gal, IG Plaster Ansylbrite, Pentair FNSP60 DE Filter, Jandy Aquapure APURE1400 SWG, WhisperFlo WFE-28 pool pump, WhisperFlo WFE-26 Waterfall pump, Raypak P-R406A-EN-C Heater, Polaris 1-470-02 Air Blower, Jandy PDA 4.1a firmware
    Jul 2010
    Montreal, Canada
    49
    Hey, thanks for the response, unfortunatley ive already put 200 gr of a product (forget the name) To increase the p.h. I waited 4 hours then put about 1 kg of calcium to increase hardness, then i was gonna start the shock process which is 4 products, then i was going to add the salt.
    Does this seem right?
    Here are my reading b4 i put anything in the pool
    Alkalinity: 90
    P.h. 7.0
    Hardness: 130
    Salt: 700 ppm
    Chlorine: 0
    Mind you, this was tested before i even ran the pump
    Right now my pool is pretty darkcan barely see the bottom, i have alot tree in my backyard
    Thanks for your help
    18 feet AGP
    SWG
    Catridge
    snewo is essentially right, though you can add salt any time.
    Adding calcium should normally be put off until everything else is balanced and you aren't doing anything special to the pool that day. Adding calcium on the same day as raising the PH can result in calcium clouding. Your starting CH level is fairly low, so you will probably be alright, but you won't know for a while.
    Don't trust test results that were taken without having had the pump running.
    Focus on shocking the pool and leave other things until later.
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Quote Originally Posted by poolnoob
    ...... then i was gonna start the shock process which is 4 products, then i was going to add the salt.
    What 4 products are you going to use to shock your pool?
    Liquid chlorine should be the only product you need to use. Running your pump 24/7, cleaning the filter often, and brushing the pool will get you through the shock process quickly.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Jul 2010
    Montreal, Canada
    49
    Basically, first a degreaser, then a product called clear(not sure whats in it) then 900 grams of xtreme shock i think this is some sort of conce trated chlorine, algicyce 40 and finally a product to remove metals
    Ive done all this and now my water looks cloudy green, i need to add salt now, can i add salt and start the clorinator, or do i need to wait a while before starting the chloronator, is it a bad idea to start the chlorinator at this point in my pool opening process
    18 feet AGP
    SWG
    Catridge
    Don't run the SWG for 24 hours after adding salt.
    Jul 2010
    Montreal, Canada
    49
    Would this help in clearing the greenish cloud , or should i be using liquid chlorine at this point?
    Thanks
    18 feet AGP
    SWG
    Catridge
    Aug 2010
    Dallas, TX
    4,052
    Liquid chlorine
    Jul 2010
    Montreal, Canada
    49
    What type of liquid chlorine an how much should i use?
    18 feet AGP
    SWG
    Catridge
    Aug 2010
    Dallas, TX
    4,052
    Going to need your pool's volume, and a good set of pool readings with from a reliable test kit. Going to need your FC, TC (or CC), and CYA at a minimum to plug into poolcalculator.com to tell you your needed shock level.
    Check this thread for more information:
    what-we-need-to-know-to-answer-your-questions-t10341.html
    Jul 2010
    Montreal, Canada
    49
    Ive done the drop test or the FC and it is close to zero (even though i did add 900g of a product called xtreme shock)
    My alkalinity is 90
    Hardness is about 200
    P.h. Is at 7.2
    My pool is 18 feet above ground so about 30000 litres
    I haven tested the cya, but i would estimate about 50
    In terms of liquid chlorine, can i use bleach (3 or 6%) found at the super maket.
    Your help is much appreciated
    18 feet AGP
    SWG
    Catridge
    Keep adding chlorine. Standard household bleach, just the plain unscented stuff with not special features, is a good thing to use to add chlorine. 6% bleach is usually less expensive for the amount of chlorine it adds, ie 3% would need to cost less than half as much to be cost effective. 6% also means less carrying than 3%.
    Jul 2010
    Montreal, Canada
    49
    Do you have an idea of the amount i should start out with or a pool of 30000 litres
    18 feet AGP
    SWG
    Catridge
    You need about two gallons of 6% bleach to raise FC from zero to 18.
    Jul 2010
    Montreal, Canada
    49
    Normally FC should be between 3 and 5 right?
    Is 18 the amount to shock the pool
    18 feet AGP
    SWG
    Catridge
    Right and right. If you don't need to shock then 2.5 quarts of 6% bleach.
    76
    Just a reminder that you are chlorinating or shocking blind without knowing your CYA value. A test kit would be best to get that value, an average value of about 3 pool stores CYA reading might at least give you a ball park to use. They test CYA poorly in general but it's arguably better than where you are now.
    Jul 2010
    Montreal, Canada
    49
    Thanks for you help so far, after adding the bleach, the pool looked alot better this morning, water is no longer green but it is still cloudy , I can now just barely see the bottom drain.
    I'm at work now so don't have time to go to the pool store to test the CYA, I can however test the P.H. and the clorine level.
    what do you suggest I do at this point? should I add more bleach, or start my chlorinator tonight
    on a side note, normally the chlorine level should be between 3 and 5, however on my test kit (drop test) the range is between 0 and 1.5, could this be another measurement?
    18 feet AGP
    SWG
    Catridge
  20. Back To Top    #20
    The next step is to get a full set of water test results now that the pump has been running for a while and you have made preliminary adjustments.
